Samsung PS50Q7 Plasma, pico fuse blown.
  • Dang
    • Aug 2013
    • 440
    Hi, I'm a bit of a novice when it comes to these things but I have done some research and it seems one of the pico fuses has blown, the Tv turns on but gives no picture, it has sound but no picture. I have a basic digital meter and have tested all voltages, they all seem fine so I can discount the PSU, the X board(far right) gets very hot with a healthy buzz so I'm sure that's working fine, the Y-SUS on the other hand doesn't, but you can still hear a gentle buzz, all ceramic fuses have good continuity, there's also another soldered to a small control board bottom right of the YSUS and that seems fine too. I've tested all pico fuses and only one shows any kind of abnormality, I used the diode test on the digital meter and from a base reading of 1 it dropped down to about 0.7, all other fuses dropped right down to zero so that suggested to me that this one had blown open, now my question is why has it blown?
    To give some back ground on the Tv, I was given it with the previous owners description that the picture started to drop out after a few hours use, then progressively over time that time frame dropped to about half an hour at which point it wouldn't produce a picture again, it does turn on and seems to react to the remote, indeed when trying to display the menu a louder buzz can be heard, then when switching off the buzz becomes less obvious so that would suggest the main board is OK, at least in my opinion.
    I've tested the eight MOSFETs(I presume that's what they are) using the diode mode on the DMM and found all eight showing the exact same reading, dropping from 1.0 to 0.405 on each of the bottom pins, middle pin seems to be cut off and top pin stays the same @1.0, this might suggest all are fine but I don't know, I shall be changing the pico fuse and hoping it's just simply that that's at fault, but considering it's a fuse something has probably caused it to blow, just not too sure what so any help would be greatly appreciated, thanks, Andy.
  • Dang
    • Aug 2013
    • 440
    Re: Samsung PS50Q7 Plasma, pico fuse blown.
    Any advice or help would be greatly appreciated. If it helps, I have experience with LCD TVs, I've fixed quite a few even at component level and I've fixed a multitude of laptops, consoles, handhelds, phones etc so I have a reasonable back ground with electronics, I haven't blown my self up yet.
      Can you post a picture of the fuse that has blown? (and the area around it...) I believe I've seen this problem before on a similar model.
      • dfergy54
        • Jun 2013
        • 57
        I had a similar issue with a 42 inch, replaced the 1 amp pico fuse and it blew again, ohmed both sides of the fuse to ground and found one side at about 20 to 40 ohms.Disconnected the cabeling to the board on the right and the short went away, followed the wiring and found eventually a protection smd chip had shorted, (8 pin if I remember right). I lifted the pin on it to prove the theory, checked on parts and found a replacement board cheaper than the parts. Replaced the board and it came back to life.Hope this helps.
        Good Luck.
        If it ain,t broke.......
        If all the smoke is still in it, it should work,
        • Babbar
          by Babbar
          04-12-2024, 01:12 AM
        • drscoot
          HP X360 convertible battery blown fuse error, not charging
          by drscoot
          HP Modelnumber: 14-dh0061nb​
          This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
          The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
          I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
          And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
          All these 3 batteries are charging...
          12-15-2023, 05:54 AM
        • beetle1303
          Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
          by beetle1303
          I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
          On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
          01-13-2025, 08:49 PM
        • jesterace
          Samsung UE46ES8000 Blown fuse but no other signs of short
          by jesterace
          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
          09-11-2024, 03:14 PM
        • whc14765
          Gigabyte 980TI Windforce - Blown PCIE Fuse
          by whc14765
          Hey,
          I have a Gigabyte 980TI Windforce. No shorts on the main 8 pin PCIE power connectors. The 8 phase buck converter inductors are showing 2.5ohms.
          The card doesn't power up at all - no lights, no fans, nothing. I noticed that all of the 8 phase inductors are showing 0V. I couldn't find a fuse for the 8pin power connectors.
          I did notice that the PCIE x16 connector 12V line has a fuse F3 (10A marked on it) which is blown. It is reading 16ohms on one end.
          1st Question: Is there some logic on the board that checks the 12V on the PCIE x16 bus connector...
          04-08-2022, 06:22 PM
