Panasonic TC-50PU54 8 blinks picture flashes then dead
  • spratt22
    • Apr 2014
    Re: Panasonic TC-50PU54 8 blinks picture flashes then dead
    I just completed the 8 blink repair on my TC-P50U50. I bought the repair kit (Panasonic TXNSS1SDUU (TNPA5623) SS Board Component Repair Kit) from Shop Jimmy. I have very little electrical and soldering experience but was able to complete it successfully. The kit comes with a diode, transitor, resistor and a chip. I tested my resistor and it still read 5.6ohms the same as the new one so I decided not to replace it cause it looked like a huge pain in the a**. I followed the panasonic tech bulletin that someone posted earlier but only replaced the diode and resistor (which are the easiest to replace) and the TV now works. I reccommend a 40W soldering iron with a pencil tip and a small flat blade tip as well as using a solder wick to clean up the old solder. Good luck to any completing this task in the future and join us in never purchasing from Panasonic again!
    • spratt22
      • Apr 2014
      Oops i meant to say only the diode and transistor
      • Molinamike
        • May 2014
        • Usa
        #63
        Do you have a link where I can purchase the repair kit?
        • tw2005
          • Oct 2011
          • 6458
          As you'll see, kits vary but hard to argue with the SJ kit price.
          http://www.shopjimmy.com/panasonic-t...repair-kit.htm
          http://www.ebay.com.au/itm/PANASONIC...item2c8046a7c9
          http://www.ebay.com.au/itm/Panasonic...item27e328f8b7
          • jasonisdn
            • Jun 2014
            • US
            #65
            Hey guys. I found this tonight since my TC-P50UT50 made in June of 2012 just bit the dust. I am fine with working on the board and all but I just wanted to make sure the repair kit Jimmy sales gives the board location. Is it cheaper and maybe better off to replace the whole SS board?
            • spratt22
              • Apr 2014
              Update. The last two weeks TV has been making a buzzing sound while I have been watching TV or movies. Today it started crackling and popping as well and it finally gave out. These noises appeared to becoming from something that drives the picture or the power since they do not occur when muted. I now get the 8 blinks of death once again. I let it cool for a while and the picture came up for about 15 seconds then shutdown and now it will not come up again. Not sure if I have the heart to repair it again.
              • tw2005
                • Oct 2011
                • 6458
                Sounds like if you had investigated the increasing noises , may have turned out the board was loose and poorly earthed since you mention arcing noises.
                Were the screws replaced or tight with the first repair? I 've read the screws are part of the problem.
                • Jeff Pepin
                  • Jun 2014
                  • 103
                  • CANADA
                  #68
                  thanks for your update .i have ordered same repair kit for a tc-p50U50 i noticed also arcing marks on the frame , for sure , the best solution are ReRouting an Hard Ground wire for all Grounds subject to arc again that i will do for sure thanks a lot , , Badcaps.net is dope!! thanks all for your sharing , i feel like home on your forum
                  • whiz62
                    whiz62
                    • Dec 2013
                    • 242
                    • usa
                    #69
                    Spratt22 did you clean arcing marks on board and frame and replace screws with lock washers? Just wondering cause I just repaired one for a neighbor and the kit I got came with new screws.
                    • Dan76
                      • Oct 2014
                      Originally posted by mcf57
                      I have a TC-P50UT50 as well. I got this TV in April 2012. First, I lost its two HDMI ports around August 2014. I was then watching my TiVo through its HD Component inputs until I could maybe get this repaired. Recently, I got the 8 blinks of death too and was not happy that it has already totally failed. I did not get the extended warranty either.
                      I figured I had nothing to lose before I took it to a local repair shop so I called Panasonic up as an unhappy customer. I explained the situation and how I was not real pleased that two components on this TV failed within 2yrs of getting it. I have a Sony that is 3 yrs old with not a single problem and would consider Sony for my next HDTV purchase.
                      Long story short....Panasonic gave me a case number and told me to take it to a local designated shop for repair (about 30mins away). Along with my receipt from best Buy, Panasonic will now cover most of the parts cost for both of these issues. It will only cost me about $150 in labor charges.
                      I personally do not like getting extended warranties and realize they are gambles no matter how you look at it. I also figure I am still coming out ahead here as the GeekSquad warranty at the time was $200 for 2yrs.
                      In case anyone else has this issue, you may want to try something similar. Can't hurt and only will require your time to make the phone call.
                      Was the tv successfully repaired?
                      Did they give you a list of what parts they replaced and or any other work completed?
                      Great input in this forum. Currently doing my homework to hopefully resolve this same 8 blink (due to lightning through the hdmi input from cable box), on a different model Panasonic (TC-P65GT30). This has been the most informative forum I have come across thus far, much appreciated to all who have posted here.
                      Thanks,
                      Dan
                      • PTHerring
                        • Oct 2014
                        Hey guys, has anyone had any luck resolving the 8 blink issue when it is intermittent? TV will power on and stay on between 5 seconds and multiple days before the 8 blink outage occurring) I have had my SS and A Board replaced (twice) so far and this hasn't done the trick. Any chance it could be coming from the power supply board?
                        • ddpl
                          • Oct 2014
                          • 5
                          I am having the same intermittent recurrence. I haven't attempted a repair just yet - may just send it in to Panasonic.
                          • tw2005
                            • Oct 2011
                            • 6458
                            If it's under wty yes, if not ouch that may be expensive. So after the SS was replaced has it been good for ages now intermittent? maybe get the back off and check the screws are tight or that he board is earthing correctly. that seems to be the issue may save the SS blowing and all it may be.?
                            have you read this
                            https://www.badcaps.net/forum/attach...8&d=1393180957
                            • dkraines
                              • Nov 2012
                              8 blink error after 30-45 minutes of being on.
                              Top screw on SS board was not tight, I can see arcing marks between the SS board and metal chassis. Why wouldn't Panasonic tighten that particular screw, the others were tight.
                              • whiz62
                                whiz62
                                • Dec 2013
                                • 242
                                • usa
                                #75
                                Yep! Same issue with my neighbors son's TV. Pretty strange.
                                • ddpl
                                  • Oct 2014
                                  • 5
                                  have you read this
                                  I attempted the repair. Before it, the TV would shut off into 8 blink mode after around 5 minutes. Now it lasts about an hour before doing the same thing.
                                  This was the state of the SS board:
                                  http://imgur.com/cN8iwyk
                                  Does it look like it's worth replacing with a new one?
                                  I really want to get this TV to work again. IMO LED is not good enough to replace plasma yet.
                                  • dimafl666
                                    • Dec 2014
                                    • 5
                                    Originally posted by pb86
                                    I have TC-P50UT50 since Aug-2012 and all of a sudden yesterday TV went bad with 8 Blink behavior. I've extended warranty so trying to go through that first.
                                    But after searching through different Panasonic service manual, it seems like issue is with specific Transistor on SS Board. Most likely Q16051 which is most commonly used IGBT in Panasonic Plasma. Attached is the Panasonic Technical Bulletin and the exact part u can order.
                                    Is it possible to post manual for TC-P55ST50 please. I have exact same problem. 8 blinking lights of death.
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      • atedesco
                                        • Dec 2014
                                        • usa
                                        #79
                                        I also was presented with a Panasonic TC-P50U50 Plasma with the (in)famous 8 blink syndrome.
                                        I noticed scorch marks on 2 SS board mounting screws: the top, and the one near the Vsus connector.
                                        Based on scorch marks, service manual flowchart, the great info on this forum and a technical bulletin (TB-13-02) from Panasonic, all suspicion fell to a defective SS board, specifically: Q051, D041 and R051.
                                        The gate resistor (R051) teseted fine, however, the diode and IGBT were shorted.
                                        These parts were replaced using the ShopJimmy repair kit, including sanding the scorch marks and installing the better mounting screws. To ensure good electrical contact, I also refreshed the solder around the screw mounting holes where the bottom of the SS board contacts the metal frame. As the screws form part of the circuit return path, (such a poor design choice!) the screws were torqued down nice and tight.
                                        The repair worked great! For about 10 minutes!
                                        The power relay clicked open, and set presented the annoying 8 blinks. As the rear case was open, I noticed the D041/Q051 heatsink was extremely hot. Analysis shows D041 and Q051 again shorted. Vsus measured about 210v+_. So I don't suspect the power supply. While it worked, picture was great.
                                        Ideas on this are welcome and appreciated before I replace the SS board. Thanks.
                                        • tw2005
                                          • Oct 2011
                                          • 6458
                                          Not sure but i think i've read some have had to replace the driver IC as well. So the resistor read correct value ?
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            11-20-2024, 08:52 PM
                                          • Biruslapio
                                            Panasonic P58V11B 8 and 12 blinks error "fix"
                                            by Biruslapio
                                            Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                            Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                            04-13-2021, 07:13 AM
                                          • FZG
                                            Panasonic AG-1000B VHS player with bad picture quality
                                            by FZG
                                            Hello!
                                            I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
                                            Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
                                            I want to know, is this something that could be solved by recapping or is the video head likely gone?
                                            Also, what mechanism is this?
                                            Any feedback is appreciated!...
                                            05-06-2024, 07:16 AM
                                          • Bazfletch3
                                            Panasonic TH-65FX800A backlight LED's working but picture is very dark
                                            by Bazfletch3
                                            Hi all
                                            While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
                                            I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
                                            From there I envisaged that the backlighting wasn't working, however...
                                            01-08-2024, 10:18 PM
                                          • kca
                                            Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                                            by kca
                                            Hello all ~
                                            I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                                            This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                                            No picture. No sound.
                                            I tested all the voltages coming out of the power supply...
                                            10-12-2023, 05:23 PM
