LG 42PC5DC plasma tv clicking on off
  • jose6326
    • May 2013
    • 707
    I picked up this tv today
    The tv powers on and the red led illuminates in front
    When I push the power button the red led turns off then a green led comes on then you hear clicking on the ps board and the red led comes back on
    When I push the power button there is no illumination of the screen because it clicks on and off quickly
    There are 2 fuses on the ps board which I found 1 blown 4A fuse on the ps board (see pic with arrow)
    There are no visible blown/bulging caps
    I did replace the blown fuse with a 3.15A fuse that I took from a spare ps board
    Hoping this would fix the problem it did not it only blew the fuse when I pressed the power button
    This fuse that keeps blowing is located in between the heat sink and the 2 big caps to the right of the center of the ps board (see pic with arrow). The other fuse that did not blow is located by the connector for line voltage
    I ordered 10 fuses from digikey so I can try to figure out what is the problem which im guessing is a short somewhere.
    Im guessing I have to disconnect the cables going to the other boards to determine if the short is coming from tbe ps board?
  • capkid
    • Oct 2010
    • 1339
    Re: LG 42PC5DC plasma tv clicking on off
    You most likely have a failed component on the primary side of the PSU. I'd pull the PSU and look for obviously blown or burned components with a flashlight first.
    LG Plasma Mal-Discharge Correction Service
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      Checked the MOSFETs on the heatsink next to the fuse that keeps blowing. See if any of them are shorted.
      Muh-soggy-knee
      • jose6326
        • May 2013
        • 707
        thanks i will check for burned components later on today
        how do you check a mosfet?
        • jose6326
          • May 2013
          • 707
          is ok to use glass fuses instead of ceramic as long as the amperage is the same?
            In general not unless you like picking out embedded glass fragments from your skin when the fuse blows. Most glass fuses can't safely interrupt high fault currents such as those available from your average plug, which will result in them exploding in many cases. I have made this mistake before, luckily I was in front of the set when fuse went pop. Ceramic fuses will retain their integrity when they fuse open.
            • jose6326
              • May 2013
              • 707
              yea i figured the glass would go everywhere if it blows.
              right now i found 3.15A fuses so i will use those for now until the ones from digikey get here
              • jose6326
                • May 2013
                • 707
                Ok so I put in a good fuse, disconnected the cables going to the other boards
                I plugged in the power cord and turned on the power to the surge protector then the relay on the psu started clicking and you can hear one of the transformers powering on and of in sequence with the relay and about 5-8 seconds the ceramic fuse blew
                So im guessing the problem is isolated to the psu?
                I checked the board and I couldnt find any visible burns or defective components
                Now I need help checking the mosfets on the heat sinks
                How do I do this?
                What kind of readings am I looking for
                • capkid
                  • Oct 2010
                  • 1339
                  You probably have N-channel mosfets: https://www.badcaps.net/forum/showpo...0&postcount=40
                  Edit: You sometimes have to test them out of circuit if your readings are questionable. You can usually just unsolder one of the mosfet's leads.
                  • jose6326
                    • May 2013
                    • 707
                    I think I figured it out
                    I put the dial on diode mode and I tested the first 2 mosfets closest to the fuse that keeps blowing
                    These are the readings
                    1-2 : 0.002
                    2-3: 0.000
                    1-3: 0.002
                    1-2: 0.000
                    2-3: 0.000
                    1-3: 0.000
                    Did I test these correct?
                    Please see pics
                    The 2 mosfets in the yellow box are the closest to the fuse that keeps blowing
                    The number on the mosfets I tested is W20NK50Z
                    Not sure who the maker is but the logo is St
                    • capkid
                      • Oct 2010
                      • 1339
                      It looks like you have shorted mosfet(s). I'd try testing them off the board.
                      http://www.mouser.com/ProductDetail/...2fw3iiJbnjc%3d
                      • jose6326
                        • May 2013
                        • 707
                        i will test the other 2 mosfets on the same heatsink furthest form the fuse blowing.
                        i didnt get a chance to last night
                          Depending on the design you -may- also need to replace the L6598 chip too.
                          • jose6326
                            • May 2013
                            • 707
                            i wish i would have seen your post earlier tom
                            i could of purchased this chip together with the mosfets to avoid paying multiple shipping charges
                            oh well
                            i will replace the mosfets first and if it does not fix the issue i will replace the chip
                            thanks capkid and tom
                            edit: i was able to add the chip to my order just in time
                            • jose6326
                              • May 2013
                              • 707
                              How do I pull the mosfet off of the heat sink?
                              • capkid
                                • Oct 2010
                                • 1339
                                You should be able to unsolder the mosfet from the board then unscrew it from the heat sink. Make sure you save the insulators that sit between the heat sink and mosfets.
                                • jose6326
                                  • May 2013
                                  • 707
                                  I desoldered the legs from the board and removed the screws
                                  But the mosfet is like glued to the heat sink
                                  I cant get it off
                                  I even tried pulling it off with flat pliers and nothing
                                  • capkid
                                    • Oct 2010
                                    • 1339
                                    Those can be a pain. I have some bent needle nose pliers that I use to get a grip on the mosfets when they're stuck. Make sure you've removed all the solder then you'll have to grip the mosfet and wiggle it until it's free.
                                    Edit: You might want to try heating the back side of the sink with a hairdryer if there are no components close by.
                                    • jose6326
                                      • May 2013
                                      • 707
                                      I got them off I just needed to use a little bit of muscle
                                      Capkid can you check my other thread for the samsung tv
                                      I need help going further on testing
                                      • jose6326
                                        • May 2013
                                        • 707
                                        Should I replace the caps on the psu even if they are not bulged?
                                        I really need to order an esr meter
                                        • beetle1303
                                          Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                          by beetle1303
                                          I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                          On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                          01-13-2025, 08:49 PM
                                        • Babbar
                                          by Babbar
                                          04-12-2024, 01:12 AM
                                        • slimmy182
                                          [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                          by slimmy182
                                          Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                          I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                          Looking on google I found this:...
                                          01-14-2023, 11:55 AM
                                        • stecos
                                          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                          by stecos
                                          Hi everyone!
                                          For my passion for technology I'm now collecting several...
                                          11-28-2022, 11:39 AM
