Philips 42inch backlight
  • PL519
    Tube lover
    • Jul 2013
    • 26
    Hi guys,
    i am referring to this thread : https://www.badcaps.net/forum/showth...t=18596&page=2. I have exchange two or more CCFL´s from an AUO 42 inch. So far i have managed to remove the upper metal frame of the display with the display laying on it´s back on my workbench and the lcd glass facing upwards. Please, can anybody describe the procedure to remove the glass safely without breaking it and remove it back after changing the CCFL´s? I had success with max. 20''ers but i´m a bit afraid with this dimension. Any help is pretty much appreciated!
    TIA,
    PL519
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    Re: Philips 42inch backlight
    remove the steel bezel,
    undo the ribbon cables from the t-con,
    then you can unclip the plastic frame that the lcd sits on and lift it as one,
    remove the diffuser plates and then you will have access to your globes.
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
    • PL519
      Tube lover
      • Jul 2013
      • 26
      thanks a lot for the advice. I finally did it your way! Those things are so damn fragile, it really caused me headaches and i was totally sweaty...! Nice experience though!
      Thanks again,
      PL519
      • attainteddragon
        • Apr 2013
        • 764
        • australia
        from now you will be able to do it with your eyes closed!
        • DanPoka
          by DanPoka
          02-15-2025, 05:05 AM
        • chestercc
          Philips TV Backlight Repair
          by chestercc
          So i'm trying to replace the LED's in a Philips TV. It's 42" with a 715g7262-p01-000-0010 backlight driver board based around an O2 Micro OZ9902CGN.
          My issue is when I replace all the LED's on one board with the new 3V 300ma ones they immediately burn out when the set is powered again. I previously tried the same thing with 6V LED's and the backlight flickered for a bit but wouldn't start.
          The original LED's which I removed which are still working start to melt and burn when given more than 3V on DCPS so I know they shouldn't be higher voltage ones.
          11-18-2022, 01:15 PM
        • ohren
          Trying to control Philips backlight manually with PWM — brightness increases with frequency...?
          by ohren
          I raised the question of whether PWM on the power board "dim" pin would be a reasonable assumption for controlling the backlight of a Philips TV (55put6101/12): https://www.badcaps.net/forum/troubl...d-tv-backlight. I didn't receive any insights there so I went ahead and tried it.
          The setup is basically:
          Rpi3 hardware PWM → 220 Ohm → NPN transistor → dim pin
          Transistor is switching the 3.5 V supply on the power board....
          12-05-2024, 11:10 AM
        • Patrick501
          Philips 55PUS6704 no picture, backlight ok
          by Patrick501
          I'd like to repair a Philips 55PUS6704.
          It turns on and you can see the backlight, hear the sound but no picture.
          When I disconnect one of the T-con cables, half of the screen turns white.
          right cable disconnected= right side white
          left cable disconnected= left side white
          When I tape like 6 or 7 pins of one cable it looks like the picture attached. I already tried another T-con board without success.
          There are no shorts on the the mainbaord and the two lcd panel boards...at leat I couldn't find any.
          Also you can notice one single...
          11-12-2025, 08:46 AM
          Design of CCFL Backlight Inverters with Frame & Bar Cores
          Summary
          Portable devices, such as notebook computers and personal digital assistants are developed rapidly nowadays, which places an increasing demand on display technology. The LCD with cold cathode fluorescent back lighting satisfies the requirements on display performance, size and efficiency.
          The backlight inverter plays a crucial role in supplying the power to the lamps of these flat-panel displays.
          The frame and bar ferrite cores, described in this brochure, are especially designed...
          10-07-2024, 04:26 AM
