Vizio Vw47lhdtv10a no power
  • Ovalking
    • Jul 2013
    • 57
    • Usa
    I have a vizio Vw47lhdtv10a 37 inch flat screen that was hit
    By lighting and was blowing fuses I put a used power board in
    It i have power going to it but nothing else does anyone
    No were to check voltages or what to do thanks
  • Ovalking
    • Jul 2013
    • 57
    • Usa
    Re: Vizio Vw47lhdtv10a no power
    Wrong number it's a vw37lhdtv10a 37 inch
      The main board is more likely took the hit also. Pictures of the main board and power supply? There may be some SMD fuses that need to be checked, also the voltage regulator ICs will need to be checked. You can also report the voltage reading on the pins (the connector between the Main board and the power supply) of the power supply
      • Ovalking
        • Jul 2013
        • 57
        • Usa
        All voltages are zero and L 16 on main board looks like the
        Tops blown off is that a fuse ?
          Can't tell without any pictures.
          • Ovalking
            • Jul 2013
            • 57
            • Usa
            Ill post some tommorrow thanks
            • Ovalking
              • Jul 2013
              • 57
              • Usa
              Here's pics of boards thanks
              • jesselyons2002
                • Jul 2013
                • 82
                • usa
                There no pics. Most likely its a main board. I work on two tv that had power surges and it was main boards that went out.
                • jesselyons2002
                  • Jul 2013
                  • 82
                  • usa
                  Ever since that I try to put surge protector on the TVs I fix.
                  • Ovalking
                    • Jul 2013
                    • 57
                    • Usa
                    Thanks was power board and main
