Technika 22-880 startup issues
  • notallbad
    • Oct 2012
    • 1190
    Re: Technika 22-880 startup issues
    Only getting 2.38v on ICE3BR0665J VCC pin in stby and 3.2v when on, Tech Sheet says between 10.5 and 25v.
      Where is your ground going?
      • notallbad
        • Oct 2012
        • 1190
        Sorry, don't understand.
        Via D701 and C704 TO Chassis???
          The negative lead of the multimeter sorry
          • notallbad
            • Oct 2012
            • 1190
            Oh, chassis screw.
            Now with neg probe to C706 neg leg.
            18v whilst led flashing, then 13.64v while in stby and 18.41v when on. So spotted my mistake there.
              OK you are now measuring the primary-side "ICE" relative to primary side ground?
              Blinking power LED is rarely power supply on these modern vestels. Usually it is a main board issue.
              What is main board model? 17MBxx-x?
              • notallbad
                • Oct 2012
                • 1190
                17MB60-3.1, I was afraid of that.
                Not sure if you have read an earlier post but in the Diagnostic page of the Service Menu it shows NOK, is this Not OK as opposed to the others that just read OK? Do you happen to know?
                  SM
                  Of interest is page 66.
                  Problem: LED blinking, no other operation
                  This problem indicates a short on Vcc voltages. Protect pin should be logic high while normal operation. When there is a short circuit protect pin will be logic low. If you detect logic low on protect pin, unplug the TV set and control voltage points with a multimeter to find the shorted voltage to ground.
                  Locate Q178 for PROTECT indicator. Test point TP202.
                  • notallbad
                    • Oct 2012
                    • 1190
                    Thats gonna be on the solder side, bummer. Oh well, here we go.
                    Aha just spotted it on component side, this is getting too easy.
                    Thanks Tom.
                    • notallbad
                      • Oct 2012
                      • 1190
                      TP202 reads 3.3v whilst flashing led then 0v whilst in stby, then 3.3v again whilst led flashing when powering on out of stby and remains whilst on and working.
                        OK, that may be OK then. But check all the voltages that feed in to it: 24V_VCC, 18V_VCC, 12V_VCC etc. The appropriate points are found at the diodes.
                        • notallbad
                          • Oct 2012
                          • 1190
                          Looking for the diodes you suggested.
                          • notallbad
                            • Oct 2012
                            • 1190
                            Whilst on
                            D184 3.29V, 5V, 3V
                            D185 3.29V, 4.3V, 2.98V
                            D186 3.29V, 3.3V, 5V
                            • notallbad
                              • Oct 2012
                              • 1190
                              Now it appears stuck in stby, no response to remote or keypad.
                              Powered down and restarted but still no joy.
                              Shall try powering down for a while and retry.
                              • notallbad
                                • Oct 2012
                                • 1190
                                U180 Adj Reg is reading Pin 3 - 8v, Pins2 and 4(tab) - 5v and Pin 1 - 4v
                                Across Pins 1 and 2 reads 1.2v.
                                Is that Pin1 - 4v looking suspect?
                                Edited - Erm, no I guess not, sorry.
                                • notallbad
                                  • Oct 2012
                                  • 1190
                                  I think this main board is screwed, the main chip U157 is running hot within seconds of being on.
                                  The front led sometimes comes on and flickers, not the usual led flashing, and other times comes on solid. No backlight on but have good 24v and 3.1v on dim.
                                  • notallbad
                                    • Oct 2012
                                    • 1190
                                    So just for future reference/interest
                                    These are readings whilst powered from mains but no response from remote or keypad
                                    1 3.1v---------11 5v
                                    2 3.1v---------12 5v
                                    3 3.1v---------13 5v
                                    4 11v-------14 11v
                                    5 5v-----------15 5v
                                    6 5v--------16 11v
                                    7 3.1v ----------17 0v
                                    8 0v--------18 0v
                                    9 0v-----------19 0v
                                    10 0v-------------20 0v
                                    • notallbad
                                      • Oct 2012
                                      • 1190
                                      I suppose it is possible the SW is corrupt but doubt it.
                                      Also presumably as the tv does not start up properly it is not possible to update the SW via USB.
                                        There is a method in the linked SM on how to update firmware without ever seeing the LCD light up (just need remote & USB key), but I'm not sure if it will work if in protect mode.
                                        • notallbad
                                          • Oct 2012
                                          • 1190
                                          What the hell, shall have a go and see, its not like its gonna break it anymore than it already is, well I guess it could.
                                          • SoulFreeze
                                            Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
                                            by SoulFreeze
                                            Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
                                            After repairing the above issue, I realized the following remaining problem,
                                            Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
                                            The computer recognizes headphones are connected and displays a popup in windows
                                            Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
                                            06-21-2025, 09:53 AM
                                          • Nagyesz
                                            Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
                                            by Nagyesz
                                            I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
                                            All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
                                            How can I extend its lifespan? Could reflow help?
                                            It has ryzen 5 5500h, rtx 2050, no soldered ram.
                                            Example of the artifacts:
                                            03-01-2025, 11:11 AM
                                          • BMCappelletti
                                            Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
                                            by BMCappelletti
                                            Hi everyone.
                                            Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
                                            Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
                                            Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
                                            02-18-2025, 12:22 PM
                                          • pwnjuice
                                            Bitlocker issues
                                            by pwnjuice
                                            Customers laptop had a Motherboard go bad and replaced it. they want to try to get data but. I am having bitlocker issues. I will list below
                                            Issue 1: When connect the drive to my computer to decrypt it I get this message. "there are no supported protectors on this drive the drive cannot be unlocked"
                                            Issue 2: When I run powershell as admin and try manage-bde -protectors -get e: I get this message. " ERROR: An attempt to access a required resource was denied. I also get the same error when I try manage-bde -status e: When I try the same with terminal with
                                            01-06-2025, 05:33 PM
                                          • Skgod
                                            Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu
                                            by Skgod
                                            Hey I am having Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu. Works fine when I open any game or whatsapp windows application. The issues are :
                                            Black screen, freeze
                                            The weird thing is that when as long as the laptop is running on igpu the problem keeps happening. But as soon as I open any game or whatsapp windows application, the laptop works completely fine.
                                            When the screen freeze or black screen I used to move the display lid up and down and it usually works like that.
                                            So can anyone tell me what would be the possible cause?...
                                            10-16-2024, 08:11 PM
