Panasonic TC-P65GT30 Yellow Vertical bar problem
  • jediplay
    • Jul 2013
    • 13
    I had it posted on a similar Pansonic thread yesterday since I could not create my own.
    The problem is two years old TV suddenly developed Vertical bar about 3” wide that is Yellow color under white background on the left side of the screen. Checking through website and found some Panasonic service training manual showing a similar symptom except all are black bar or red bar with no background showing. My TV shows the picture except it has yellow tint on majority of its presence. The possibilities are C3 board, or A board with occasionally PDP panel driver IC which is embedded and cannot be replaced. Am I on the right path? Any input would be helpful.
    UPDATE: I have ran some self diagnostic and nothing really stands out. I am attaching pictures for analysis. Picture 008 of self check shows yellowish vertical bar on the left of the screen.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P65GT30 Yellow Vertical bar problem
    I still think it's worthwhile doing the mirror test in service mode under option first.
      Yes, and if that shows bar in the same place, a very common issue on these sets is a loose connector on that part of the plasma panel, easily fixed by just reseating it (power must be off while doing this.)
      • jediplay
        • Jul 2013
        • 13
        Will try that tonight. I'll update tomorrow to see what happens.
        • jediplay
          • Jul 2013
          • 13
          So I tried the reversing the mirror function tonight and it did not follow. I guess that means I have to check C board or connection to the C board?
            Yes. Connection only to be removed or inserted with power off.
            • jediplay
              • Jul 2013
              • 13
              I'll have to dismount the TV from wall stand to remove the back cover which is a pain but to save $$$, I'll have to do this. It looks like the weekend project for me.
              I'll post what I find.
              Thx
              • jediplay
                • Jul 2013
                • 13
                Thx
                I had my friend help me to dismount the TV from the wall and I had to install the stand to remove the back cover. So many screws to remove but it was worth it.
                Unlocked all of locking tabs from the PCB and removed the C3 PCB mounting screws so I can wiggle it a bit. Reinstalled everything back and turned on the TV and the yellow bar was gone.
                Thanks for all your help folks!!!
                TV looked as good as it was new except I lost all my calibration setting due to Factory reset.
                One question I have is when I performed Factory reset, does that roll back the color tweaks done at service mode? I have made some tweaks with Red, green, and blue CUT values but I can't find my notes for the original setting.
                  Factory reset from service menu will reset all of those presets, but I think if you do it from the user menu it won't affect them.
                  • tw2005
                    • Oct 2011
                    • 6458
                    Nice!
                    • AquaMan Ua
                      by AquaMan Ua
                      05-17-2025, 09:40 AM
                    • Returning Buick
                      Viewsonic G810 vertical deflection problem
                      by Returning Buick
                      I have a G810 monitor i've had for years but it has developed a problem with vertical collapse. Is there anybody here who has worked on these and can help me find where the circuit even is for the vertical deflection?
                      04-01-2025, 07:57 PM
                    • multimesut
                      Dell 2007FPB Yellow Light Problem
                      by multimesut
                      Hello friends,
                      A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....
                      11-13-2024, 07:00 AM
                    • hugocarmo
                      Panasonic TX-24A1UN CRT Sound and Input problem.
                      by hugocarmo
                      Hi.
                      I´ve been given an old CRT from Panasonic, it´s almost new, it was storaged and almost not used since bought.
                      It is imaculate inside, almost no dust or debris inside.
                      The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
                      So I started to look for a service manual, I found one, and started from the beginning.
                      Most of the times the caps are the problem so I orderer all the caps for all boards,...
                      04-26-2025, 07:45 PM
                    • renech
                      panasonic TH-42PC77U plasma television half screen problem
                      by renech
                      hello,
                      I hope someone on this forum can assist me.
                      I have a panasonic TH-42PC77U plasma television.
                      the lower 1/2 of the screen has become flaky....in and out, then finally goes black and you can only see the top portion.
                      i have performed the reset to default settings quite a few times. Panasonic recommended..did not believe this would help...it didn't.
                      I have removed the back panel and looked around for something obvious...burn marks in a board, etc....nothing obvious...
                      I have read some posts that suggest the problem is related to the boards on the left...
                      12-12-2022, 06:53 PM
