Samsung PN50C490B3D - Mainboard Problem
  • Emerica
    • Jul 2013
    • 7
    I have a samsung plasma a co-worker brought in to me after finding out I've fixed a few other TV's. He was going to throw it out otherwise so I figured why not have a look.
    He said it made a quick hiss/buzz when it went out.
    At this point I think I have the problem board isolated but I want to confirm before buying any parts.
    The tv when plugged in would turn itself on.
    When powered up, there were tons of lines and artifacts over most of the screen. More on the top of the screen, some of it would come and go, but never went away. Mixed colors.
    After checking voltages and getting back what I should it left me a little confused.
    I had a look at this video : http://www.youtube.com/watch?v=JjrwTZC5nVg
    And gave the process a shot, i put a jumper from a cdrom on the logic board.
    And shorted pson to gnd.
    The tv is now up an running the test patterns and looks great. No lines, no problems.
    Can I safely assume that the main board is the problem here.
    Re: Samsung PN50C490B3D - Mainboard Problem
    That would be a good diagnosis. I have never seen that video before, very useful. Wonder if more of those are available.
    • capkid
      • Oct 2010
      • 1339
      Great video. Thanks for sharing.
      LG Plasma Mal-Discharge Correction Service
      • Emerica
        • Jul 2013
        • 7
        Left the tv on overnight running the test patterns. Not really sure if that's an ok thing to do. Came in to see nothing on the screen, PSU barley putting out any voltage. Going to replace all of the psu caps, see where I get with that and go from there.
        • capkid
          • Oct 2010
          • 1339
          I thought you'd determined that the main board is the issue????
          • Emerica
            • Jul 2013
            • 7
            I had, until I left it on the test pattern overnight and then came into find nothing on the screen in the morning. Now the psu isn't putting out good voltages.
            So even if I had a mainboard replaced or repaired, the tv likely would have died out in use soon after, maybe taking other components with it.
            I'll update as I work on it, I ordered caps yesterday, they haven't shown up so far today.
            • capkid
              • Oct 2010
              • 1339
              I don't know much about test pattern generation, but I was wondering if there was some sort of "timeout" issue. I'm interested to see the outcome.
                09-07-2024, 05:50 AM
              • howardc64
                Samsung UN55JU650DF network/streaming problem
                by howardc64
                Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                07-09-2025, 12:44 PM
              • Malva
                Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
                by Malva
                I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
                Mainboard model: EAX65684604
                PCB marking: EBT62954607
                SPI chip: Winbond W25X20CLNIG Problem description:
                Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
                After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
                • I bought another
                06-25-2025, 02:07 PM
              • Chrissygizmo
                Sony KD-55XG9505 lines on screen problem
                by Chrissygizmo
                Hello again everyone,
                This is my latest mission, to try getting this Sony tv back to normal working order…
                I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                02-19-2025, 11:31 AM
              • StromarMiki
                Change mainboard samsung UE55NU7023 with another UE65NU7025 and have color problem
                by StromarMiki
                Hi, i change mainboard for my TV samsung UE55NU7023 with another UE65NU7025 and have color problem. Everything else works great only color problem. Only change eprom 24512D. How can I change the T-con parameters from 65 "to 55". Im asking for help....
                11-06-2021, 06:32 AM
