Plasma Cracked Screen Question
  • Glitcher
    • Mar 2013
    • 673
    • USa
    I noticed that whenever there's a plasma with a cracked screen that the picture stops working along with it.
    I know there's the panel itself and then the outer glass. I've never seen a plasma that is cracked only on the outer glass and would still work. And how do the internal panel get cracked if its protected by the outer glass (besides having it dropped hard). Especially with those that have something thrown at it and the glass cracks. Is it possible for plasmas to still work with only the outer glass cracked?
  • capkid
    • Oct 2010
    • 1339
    Re: Plasma Cracked Screen Question
    If I remember correctly, the tech who runs the plasmafix.com site has replaced the outer glass on a plasma TV whose panel wasn't damaged: http://www.plasmafix.com/plasma.php I'd imagine that an impact that's strong enough to crack the glass would also impact the panel in most cases.
    LG Plasma Mal-Discharge Correction Service
    • R_J
      • 9624
      Some plasma tv's had another glass in front of the plasma panel, older Panasonic, L.G. and others had this. I replaced a couple of them.
      If the actual plasm panel is cracked and the gas leaks out, you will not get a picture.
        Some newer thin plasmas will show an incomplete image if cracked, which will go away after a few days usually.
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • Alicat
          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
          by Alicat
          Stopped by this site trying to fix my parents Panasonic Plasma TV.
          Model number is TH-50PZ85U
          Power comes on and the red power light stays on solid.
          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
          I also hear a few clicks.
          I also think my parents said there was a thunderstorm and the TV failed after that.
          Section 6 in the service manual talks about power and no screen,...
          10-30-2024, 10:09 AM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
        • Zelek11
          Panasonic Plasma screen interference on left half of screen
          by Zelek11
          My Panasonic Plasma model P55VT50 has started displaying "interference" on just the left half of the screen only (left when facing the screen). Sometimes it's concentrated in about the first 30 seconds after startup, then disappears. Other times it's fine at startup and then randomly does it later on. When it flashes the interference it's very quick and doesn't stay on the screen unless it flashes repeatedly in a row.
          This image is a screen shot from a video I took. This is an example of the interference at its worst. Often the interference is much smaller...
          10-14-2022, 04:54 PM
