I have a 50" vizio plasma tv that has audio but no picture when the tv is on the screen looks like it's turned off LEDs light up on the control boards when the tv is on I would like to fix it myself I'm just not sure what's wrong with it it could be one of the sus boards if anyone can help me I would really appreciate it thanks
Vizio P50HDM sound but no picture
Tags: None
Re: Vizio P50HDM sound but no picture
You more than likely have a bad Y-Sustain or Z-Sustain; check the fuses on each sustain board. The IPMs under the large heat sinks fail on these TVs. There are quite a few threads on this forum for this exact issue. Also, check your power supply VS and VA output voltages.Last edited by capkid; 07-21-2013, 11:35 PM.
by ggil44Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
Assuming...7 Photos -
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by IerwinHello everyone,
Anyway I still fully expect that there has been something seriously damaged... - Loading...
