LG 42lk450
  • Terencej11
    • Jul 2013
    • 5
    • U.S.
    LG 42lk450
    The picture went out and a guy for them checked out the tv and the said the Main Board went out. Is there anyway to fix it and if so how much would it cost!
    Re: LG 42lk450
    In a dark room, can you see a glow from the screen, or is it completely black?
    You have a digital camera? A digital multimeter / voltmeter?
    • Terencej11
      • Jul 2013
      • 5
      • U.S.
      Re: LG 42lk450
      Completely black.
        Re: LG 42lk450
        Ok. You have a digital camera? A digital multimeter / voltmeter?
        • Terencej11
          • Jul 2013
          • 5
          • U.S.
          Re: LG 42lk450
          Unfortunately no, only have a iPhone for pics.
            Re: LG 42lk450
            Depends what iPhone, but should be acceptable if decent resolution and lighting capable.
            But you will need to get a multimeter if you want to diagnose the fault. You can buy one for under $10 from many places.
            • Terencej11
              • Jul 2013
              • 5
              • U.S.
              Re: LG 42lk450
              Ok on the camera, but would I need to get a multimeter when he told me it is the main? Thanks
              • capkid
                • Oct 2010
                • 1339
                Re: LG 42lk450
                I never assume that a tech has properly diagnosed an issue. I had one TV, where I knew what was wrong with the model based on past experience, and the tech's estimate for the original owner was WAY wrong.
                LG Plasma Mal-Discharge Correction Service
                  Re: LG 42lk450
                  In addition techs like to simplify things for customers, a "main board" can mean a power board, main (video) board or T-con board...
                  • goodpsusearch
                    Sony STR-DE445 did I get a faulty IC?
                    by goodpsusearch
                    Hello, I got this AVR for cheap and tried to fix it as a fun and learning project.
                    First the audio video receiver would turn on but had no sound at all, but no "PROTECT" message.
                    So, I opened the metal case and noticed some marks showing that some liquid has been spilled on the amp. Those water marks were found on the main board and the digital board.
                    I disassembled everything, then checked every single cap on every board of the amp and recapped when needed.
                    Also fixed A LOT of cold solder joints and also done some modifications,...
                    04-15-2023, 04:16 PM
                  • wolf1976
                    is there any univarsal wifi motherboard that supports and digital tvs ?
                    by wolf1976
                    hi i want to convert my simple digital tv because the motherboard is dead to wifi motherboard but with the ability has and tuner for digital channels DVB-T compatible in europe
                    is there ?
                    do you have to suggest me one ?
                    thanks on advance...
                    01-05-2025, 04:29 PM
                  • falcontech
                    Denon Mc6000 channel 1 completely non-functional
                    by falcontech
                    Hello
                    I need your help with a non-functioning channel on this Denon controller. I noticed the problem because, with the mixing software, the channel appears completely off and none of its controls work. At the top of the channel, like the others, there's a selector switch that moves between MIDI and external audio inputs. I also tried connecting an audio source (since it's also a standalone mixer) and I got no input. The flat cable connecting this panel to the sound card is fine. I'm attaching a photo and the service manual. I hope someone can help me resolve the issue. Thanks....
                    09-04-2025, 09:03 AM
                  • max-power
                    Dell E6540 laptop completely dead after dssasembly
                    by max-power
                    Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                    that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                    After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                    03-24-2025, 08:49 AM
                  • bohaboha
                    ADVICE FOR BUYING A DIGITAL MICROSCOPE
                    by bohaboha
                    Hi I'm thinking of buying this :1080P 4K HD Industrial Microscope 150X C-Mount Lens 48MP/13MP Digital Camera HDMI USB-C VGA Measurement For PCB Soldering DIY it's on ALiExpress : https://www.aliexpress.com/item/1005...av-description
                    the one i choose is the D full Set
                    maybe you can advise me or maybe someone who has similar who can give feedback on it very grateful for...
                    02-24-2025, 07:13 PM
