Hisense H32V77C Vertical white gray black line problem
  • BadCapsNYC
    • Jul 2013
    • 3
    I replaced T-CON board but it's still like this. What should I do next? Am I suppose to measure the voltage of those white connectors while power is on?
    Re: Hisense H32V77C Vertical white gray black line problem
    What white connector, the ones on the power board? If so then yes, you should have power applied while measuring them.
    • bdalkiran
      55EC930V white vertical line appeared (need help)
      by bdalkiran
      Dear All,
      I have 7yrs old LG OLED 55EC930v. One day a white line appeared on mid of the screen. 10mins later it was disappeared. When turned on tv again it was appeared again. Currently when power on tv is clicking sound relay, LG logo illuminates, 3 seconds later clicking sound relay and tv goes off. Screen is black during this on off period. When trying with service remote(pwr on) , clicking sound, white vertical line appears on screen(drawing line from up to down) and clicking sound then tv goes off. Please see video below.
      Please advice how to proceed and what is the...
      01-13-2023, 04:16 PM
    • otaku_nut
      Vizio E701i-A3 fixed but now has red vertical line
      by otaku_nut
      Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
      08-19-2025, 06:11 PM
    • Raulnn
      Hisense LTDN40D36EU thin black vertical line
      by Raulnn
      good evening!!! I have this tv with a line that occupies 1 or 2 pixels in width. it has a solution? Can you do a test to find out if it's a panel or something else? Having the tcon integrated into the panel makes everything difficult. I have pushed on the flex attached to the panel, on both sides and there are no changes. I don't know what else I can do... the integrated ones that go on the flex get hot, but without burning yourself if you put your finger on it. to see if someone can help me. I attached a detail photo of the line. Thanks in advance...
      12-30-2022, 05:45 PM
    • kca
      by kca
      Hello all ~
      08-31-2025, 06:38 AM
    • TrueSword88
      Kogan - KALED65XU9220STB - Blue Vertical Line
      by TrueSword88
      Hi all.
      I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
      The line just happens to coincide with the end of COF and start of the next COF (attached).
      The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
      Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
      Hoping to fix...
      05-05-2023, 04:28 PM
