toshiba 37xv555d inverter board problem
  • WALTO TDI
    • Jul 2013
    • 21
    • uk
    hi all, please can some one tell me what values the capacitors are supposed to be on the inverter board for this toshiba tv. 37xv555d.
    purchased this as a non worked but capacitors missing off inverter board??
    think they should be 35v 680uf.
    please could somebody confirm this for me.
    does any one have an inverter board lying around for this tv?
    thanks
    Re: toshiba 37xv555d inverter board problem
    Part # of inverter board?
    • WALTO TDI
      • Jul 2013
      • 21
      • uk
      Ppw-ee37vf-0 rev1.0
      thanks
        This image appears to indicate 680uF/35V
        http://assets.shopjimmy.com/media/ca...6632l0490a.jpg
        • WALTO TDI
          • Jul 2013
          • 21
          • uk
          it looks like the caps had leaked over the board so the previous owner had taken them off the board for some reason?
          is there anything in particular i should look for on the board before replacing the capacitors?
            Often, it's just those caps that go bad but in rare cases the FETs and controller chip can go bad.
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • lostone
              Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
              by lostone
              Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
              First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
              When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
              05-19-2024, 11:40 AM
            • PNI E.
              Dyson v15 problem with the dust detector board
              by PNI E.
              Hi guys, I have a Dyson v15 that didn’t work. The battery blink 10 times. If i disconnect the cable of the dust detector board, the Dyson turn on but after some seconds stop because didn’t feel the flow of the air because I disconnected the bird sensor, if I connect the Dyson is death. I notice the big mosfet I think with 3 pins. If I check the mosfet I have a short circuit from the center pin ne the left pins…so I think that s the problem or I wrong? The problem I can’t understand what type of mosfet is….someone can help it s hard to find. New board...
              10-02-2025, 10:18 AM
              09-06-2024, 05:27 AM
            • huj3r
              Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
              by huj3r
              Hi there!
              I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
              Photo of the situation after the black shadow dissipates:
              After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
              I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
              > This indicates HFR Communication error. [ HFR Communication...
              08-15-2023, 10:55 AM
