Hisense (emerson) LTDN-42v68US no picture, yes sound
Re: Hisense (emerson) LTDN-42v68US no picture, yes sound
That makes 2 of us. I did the exact same thing as previous test except power was ON for the tv.
Multimeter set to 200 (ohm x1), black lead against the frame red lead on FP1 top. Red on FP1 bottom was no reading. Now got 3.6 steady as noted, varies with how I hold probe.
Maybe I screwed something up beforeComment
There definitely is a short on the tcon, since the top of FB1 to ground measures about half an ohm.Muh-soggy-kneeComment
Well I am not going to order that board. That would put me $100 into it with no clear idea how to attach it and no 100% sure another board is not acting up.
I would like to do 1 of 2 things since it is essentially trash with some boards I can pull. First, how bout jumping the fuse with a thin wire to each end and see if I get a picture for a few seconds.
Second, try my hand at replacing the fuse itself. I have a local store that does pcb parts that I can probably get one at. Just need to know what to get!
Thoughts?
ThanksComment
Thoughts?
ThanksMuh-soggy-kneeComment
Nothing changed with a jumper.
So I removed the fusegonna see if I can get a new one. Should be pretty cheap. Nothing to lose now.
I think I can assume that since nothing changed once the fuse was out in regards to the symptoms, I can call the other boards working and sell them off if a new fuse does no work.
Thanks for the help.Comment
Thanks for the help.Muh-soggy-kneeComment
I placed one end of a wire on one end of the spot where fuse was and one on the other. Not secured or anything, joust resting there. Placed mm on ohm at 200 and (it jumped a lot, probably since nothing was really connected) and I was getting it to climb and climb up to 100+
So I am thinking that the board is otherwise good, but I am still out a fuse. My parts store does not have them and I still need numbers for that part of the board so I am not guessing on which fuse to grab. Guy behind the counter suggested a regular glass fuse and holder carefully soldered into place.
I can say that my above test is very hard to reproduce. Probably because I do not have anything really connected. I tried a bit of solder but I do not have a fine tip. Think it is not ensuring a good connection.Last edited by Jim1590; 07-09-2013, 08:36 PM.Comment
I can say that my above test is very hard to reproduce. Probably because I do not have anything really connected. I tried a bit of solder but I do not have a fine tip. Think it is not ensuring a good connection.Muh-soggy-kneeComment
ahh oh well. I will just part it out on ebay. I can probably be pretty confident the other boards are in good shape.
Thanks for the help. Maybe now I will look back at a 26" that has been sitting under the bed with a bad power up for the past year!Comment
I heard back from a guy on ebay after a few days who is willing to carefully cut off his tcon and maybe I can splice onto my panel. But when wife got curious to what I was doing and I was showing her the issue she ripped a ffc off the panel. Is it fixable so I can try the splice, or is this panel ain't gonna work again.
Looks like it was held on by silicone only..... they must have saved at least $1.50 in making this thing.Comment
No, that can't be fixed unfortunately. There's something like 300 precision aligned connections on that with 0.01mm spacing or something tiny, no way you'd ever line it up again properly.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by tomketczDoes anybody have schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ ??
by ermalsHi all!
I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
3. I've checked voltages... -
by BadCapexHi,
I am yet another unfortunate owner of a 65H6570F with a main board that failed due to an inherent flaw with the eMMC.
Reference: https://www.badcaps.net/forum/showthread.php?t=117406
The exact replacement board for a 65H6570 model TV is RSAG7.820.8831/ROH (aka 265223, aka 244991). It is very rare or expensive ($150+) to purchase currently and arguably not worth it if they're all just ticking time bombs.
A very similar board was identified in the above referenced thread, RSAG7.820.10315/ROH. It is more reliable, cheap, plentiful, and... - Loading...
