Sharp LC-37GA9E tries to start but no go
  • PowerAmpFreak
    • 982
    • Sweden
    Hi all.
    The set tries to start up, all voltages from PSU seems to come up fine, +24V to inverter, but after a few seconds it shuts down.
    I would guess this is due to a faulty inverter.
    I've included one overall picture and one close up of backside of inverter boards.
    Initial measurements of inverter transformers both primary and secondary sides didn't reveal anything suspect.
    There are three fuses on the two inverter boards and they are fine aswell.
    Any advice is welcome. Thanks!
  • PowerAmpFreak
    • 982
    • Sweden
    Re: Sharp LC-37GA9E tries to start but no go
    Tom66, I found a service bulletin for those inverters at your splendid webpage, which pointed out the inverter mounting screws as the main problem. Could this be the problem in this set, aswell?
    • PowerAmpFreak
      • 982
      • Sweden
      Anyone?
      • PowerAmpFreak
        • 982
        • Sweden
        Found it. The powerswitch was bad. It appeared to me the switch was just a tact switch, but the fault was that it didn't stay pressed (toggle switch).
        So a new switch will fix this!
        • JFarm
          Sharp Aquos LC-46E77UN inverter testing
          by JFarm
          I picked this TV out of a trash pile. When I plug it in I can hear the relay on the power supply “click” almost immediately, and then 7 seconds later there is another “click” and the power/OPC LEDs start to flash: two pulses on the power LED, one on the OPC LED. I didn't notice any sign of life from the backlight, but more on that below.....
          The service manual () says this is a “DET_10V error: UR10V or A9V is not applied”, but after checking several voltages I believe the power unit is tripping off due to an overload as soon as the backlight tries to come on; this kills...
          03-21-2021, 11:10 AM
        • organman
          Sharp LC-60LE633U Inverter output voltages
          by organman
          Greetings, I have a Sharp LC-60LE633U when powered up only the V light comes on. I have checked the LED strips and they all light up. When the LED's are plugged into the PS board I get an output voltage of 74v DC. If I unplug the LED's the output voltage on the PS is 184v DC. Does this indicate a weak PS?
          Thanks...
          03-22-2023, 06:47 PM
        • organman
          Sharp LV-60LE633U inverter output voltages
          by organman
          03-13-2023, 06:48 PM
        • x_orange90_x
          by x_orange90_x
          01-29-2025, 09:24 PM
        • Gentian
          APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
          by Gentian
          I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
          It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
          03-06-2023, 07:07 AM
