Vizio 50" Plasma model P50HDM with distorted picture
  • aaronwt6
    • Apr 2013
    • 855
    • US
    OK. I haven't really messed with any Plasmas yet but I have someone I sold an LCD to that would like me to take a look at one. I wanted to see what everyone's opinion was before I proceed on picking it up due to its size and weight. If the guess is an expensive repair I probably won't bother. I've attached a couple pics of the screen.
    The other strange thing is he says the picture is perfect playing a PS3 on the same input.
    Thanks in advance for any advice or tips
  • capkid
    • Oct 2010
    • 1339
    Re: Vizio 50" Plasma model P50HDM with distorted picture
    Which input is being used? Is the same cable used to test and compare the PS3-to-TV connection and the AV device-to-TV connection?
    LG Plasma Mal-Discharge Correction Service
    • aaronwt6
      • Apr 2013
      • 855
      • US
      Same cable, same port. Seems real weird to me.
      HDMI and he says both HDMI ports act the same way.
      Certainly not a panel fault given the game senario though.
      • aaronwt6
        • Apr 2013
        • 855
        • US
        I told him to check the resolution output on his blu-ray that he's using for Netflix but doesn't seem like that could cause the issue either.
        • capkid
          • Oct 2010
          • 1339
          It sounds like a main board or control board issue. Does he use a broadcast device (satellite, digital cable, etc), and do they show a proper image?
          • aaronwt6
            • Apr 2013
            • 855
            • US
            He says anything but the game looks distorted. May not even be worth the trouble. I'll let you know what he decides. I was kinda thinking main board as well. If he brings it over I'll check out the other inputs and report back.
            • Jim1590
              • Jul 2013
              • 98
              Sounds more like a problem with the signal coming in. What else does he have going in that he can test off of. If just this one av and PS3, hook up something else. Maybe the hdmi out on the av is bad. If you do take to your house, make sure you bring his av device and HDMI cable to verify you can reproduce.
              You may want to take the back off at his house and write down the board numbers. That way you can give him prices for replacement boards without lugging the thing back and forth.
              As someone who loves my Hitachi 50" plasma to watch, I really hate fixing the things. You got your standard couple boards and then you also have X, Y main and buffers, Z boards. Oh and if you replace the Y, you better replace the buffers as well! A plasma is the only one to beat me so far where I just parted it out from frustration.
              • capkid
                • Oct 2010
                • 1339
                He already mentioned that any HDMI device connection on both HDMI ports is producing the distorted image, except for the PS3. The one question I have is whether any non-HDMI connections result in a distorted image.
                I'm not sure if you're referring to Hitachis specifically with regard to replacing buffers when the Y-Sus fails, but that's not always the case with LG-based models. I personally prefer to work on plasmas over LCDs.
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  My opinion, it could either be a software problem, or a problem with the HDMI chip. Supposedly the chip can run hot, not sure if that is so for this particular model though.
                  Seems like it could be noise, but then what is different about the way the PS3 outputs hdmi? I don't know
                  Muh-soggy-knee
                    I'd say loose LVDS if anything.
                    • aaronwt6
                      • Apr 2013
                      • 855
                      • US
                      Thanks again guys. I'm going to see if he wants to drop it off. Sure would be nice if it was just a bad connection.
                      • KYBOSH
                        Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                        by KYBOSH
                        Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                        No picture but you hear the TV static (white noise) playing loud and clear.
                        The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                        But it seems they didn't get too far and just left it.
                        When I first took a look I was amazed at how pristine the inside looked.
                        Its as if the TV had been in a time capsule.
                        Caps looked like they were just pulled off the self.
                        Copper coils had no sign of corrosion on...
                        02-01-2023, 11:10 PM
                      • gavric
                        Vizio M70-C3 Half picture is bad, main board on its last leg?
                        by gavric
                        Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                        When tv powers on vizio V logo shows nice on whole screen. picture 1
                        When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                        When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                        When i click video to start playing picture goes black(like when you change...
                        09-02-2021, 08:55 PM
                      • ChattFix
                        Samsung UN55TU700DFXZA Distorted Picture
                        by ChattFix
                        I have a Samsung UN55TU700DFXZA with a distorted picture and I thought it was a bad panel. I had a similar board with one number off and still tried it to see what the issue could be. The picture came out clear with only missing blue hue I think. I found a replacement board for $30 but wanted to learn if this would be the main IC or possibly something else. I don't have service manual so looking to learn about these cheap sets....
                        06-02-2024, 03:50 PM
                      • KYBOSH
                        Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                        by KYBOSH
                        Saved this beast from the landfill this weekend.
                        Manfactured July 2013 in Mexico.
                        I love working on plasma TVs.
                        Its been a while but I was lucky enough to find 2 this week.
                        The TV powers on and stays on but no picture. Havent checked for sound yet.
                        No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                        Will start troubleshooting tonight.
                        10-17-2024, 01:17 PM
                      • ggil44
                        Vizio M65-E0 No Picture, No Sound
                        by ggil44
                        Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                        09-03-2024, 08:30 PM
