Sony KDL-46EX400 2 blink error code
    Re: Sony KDL-46EX400 2 blink error code
    Need to look at the circuit diagram of the latching circuit since it receives 3 signals (excessive 12v, excessive PFC voltage, excessive temperature) which any one of them can trip the circuit. It is a matter of finding out which one is tripping or the latching circuit may be at fault itself, this is where the diagram comes into play to narrow down the cause of the problem. You can disable one of the 3 signal at a time to find out which one is sending that signal to the latching circuit.
      Hi Bud, did you have a chance to look at this TV?
      Thank you,
      Tibor
        I know I found the training manual but I do not remember fi you or I find the service manual for it or not, do you remember? It is a long thread and I just do not have the time to look through the whole thread again.
          Never mind, you have it on post 56.
          OK, I will have to down load the service manual tonight:
            I have just made an offer on Ebay for a mainboard($70). The TV has a broken screen, pictured in the ad and he is only a couple miles away from me, in Burbank.
              Well, that service manual does not have schematic diagram!
                Picked up the board from the seller's store and installed it and it worked since Saturday. Let's hope that I won't have any issues from now on.
                Most likely, the other mainboards were bad boards.
                Thank you for the help.
                Now, I need to go back to the LED LG 42LV3500 with the restarting issue? Any pointers?
                I'm thinking, that I should pick up a mainboard for that too.
                  Did you take the voltage readings so we will have a ref. info for the next time?
                    No I haven't.
                    Should I take all the voltages from the PS connector?
                      Yes, we need to see the 12V, 24V and the PFC voltages, from you have posted, they are not at extreme level at all, this will tell us if the detection circuit is at fault or not. The more info you have the better. You might as well take some reading on the inverter board also like the LD, FB. The power supply board: BL_ERR, INV_ERR etc.
                      Take the reading when TV is off and when TV is on.
                        One thing that I have noticed with the bad board that the T_Con ON voltage it was almost missing(0.014V), this voltage should have started up the T_Con 12V to supply the T_Con.
                        In my opinion, there it was the problem.
                          I just got one of these things in
                          Thanks for all the research you guys have done thus far
                          but I have a delemma wether to invest anything in this or not
                          its a 2 blinker KDL46EX500
                          after looking at your schematics I got to power board to give me everything but backlight
                          the BL on from the main board is low all the time
                          but if i open it and provide my own 3.3v it still does not turen the BL on
                          the TCON on never goes high
                          but if i short the transistor as you stated it does put out tcon 12v
                          now here is the delemma since the power board should be able to produce a BL with BL on going high ....
                          I have nothing not even trying
                          the power board must be bad in this area
                          but the main board wont tell the BL to turn either or the tcon but it does tell the rest of the board to run audio 12 12v etc ...so it looks like i have a bad power board and a bad main do you agree
                          ?? or does the power board need something else to fire HV for the BL?
                          dimmer???
                            Did you try forcing the power supply, to turn on with resistors from standby voltage to PS_ON and another one to the BL?
                            This way, you can see if the voltages are there and the backlight is working or not.
                              Hello fellas.
                              I have same tv as anthonystv KDL46ex500. Tried the resistor 1k resistor between Stb3.3 and Power On and I'm not getting any 12v. My readings are all 0 except the Stb, Power on and Ac_off_det that read 3.3v. Any suggestions? Thank you
                                Check BAL board on up side behind cooling frame, Fuse F3703 smd 3,15 A blowed.
                                When it`s defective check also the little capacitor between fuse and ground. Most of the time is shorted. Removing the capacitor and replace the fuse and the TV is back working.
                                See picture:
                                I hope this will work. Also when the TV is not give any error but the green led is working check the same positions.
                                Greetings Patrick www.mofix.nl
                                  sorry ... wrong thread
