LG 50PG20-UA HD Plasma issue...
  • pansatdishman
    • Jun 2013
    • 110
    Hello, I have a 50" Lg Plasma HD model 50PG20 the picure works fine but about the 3rd of the way down it has about a 1 inch horizontal line across the screen, I have not done anything to this tv yet what would you suggest and what is the issue?
    thanks
    Picture of the tv screen
    Bad upper y buffer board?
    Re: LG 50PG20-UA HD Plasma issue...
    Upper Y buffer would be my guess.
    • pansatdishman
      • Jun 2013
      • 110
      is there a way to fix the buffer board, i'm use to fixing power supply's but i know these circuit board are way smaller. is there a way to check to see if its the board or the pannel?
      thanks tom66
        There is no way the panel could cause this in my opinion. Repairing buffer boards is possible, but may not be worth it depending on the price and your ability. The buffer chips require good soldering skills to replace. If you're up to replacing a 128 pin chip with 0.5mm between pins, you may be able to do it. Otherwise, swap the board.
        • pansatdishman
          • Jun 2013
          • 110
          Alright thanks, I'm not that good at soldering lol I would cause more damage to it then I would fix it lol
          that board says,
          EBR50039007
          YDRVTP
          HS500891031
          are there any other boards with different numbers that are compatible?
          thanks for your help
            Looks to be around $63, new:
            http://www.partstore.com/Model/LG+El...R50039007.aspx
            Not bad really, used prices are around $50~60 but all seem out of stock.
            • pansatdishman
              • Jun 2013
              • 110
              Thanks for the reply unfortunately i'm in canada so i'm going to hve to search a little harder, thanks for your help though its greatly appreciated
              • pansatdishman
                • Jun 2013
                • 110
                are EBR50039005 and EBR50039007 the same and interchangeable?
                thanks
                  They may be. To be sure, you will need to see if all dimensions and connectors are the same, and that it is used in the same plasma panel (not TV model, the plasma glass itself, which has a sticker on the metal plate e.g. LG Electronics PDP50G8#####)
                  • pansatdishman
                    • Jun 2013
                    • 110
                    I was just curious as that site says EBR500039005
                    Here's my panel details:
                    It's a Mexico model,
                    the sticker says:
                    Model: PDP50G10343
                    Mexico 2008.09
                    Thanks for your help
                      You need to check if those boards came from a PDP50G1 panel but they'll probably work.
                      • pansatdishman
                        • Jun 2013
                        • 110
                        Thanks, sorry for all the questions i'm new to this so does this mean an 05 and a 07 board are interchangeable
                        http://www.shopjimmy.com/catalogsear...?q=EAX50051102
                        thanks
                        • johnboy1313
                          • Nov 2012
                          • 1959
                          Looks like it. They both show EBR55323602 as a substitute.
                          • pansatdishman
                            • Jun 2013
                            • 110
                            Thanks for the help, I just tried turning my tv on today, the back has been off it for months, now i get sound but no picture (i haven't changed the y buffer board yet) i noticed the back of it is fairly dusty and the power supply makes a hum when on. i think i have a bigger issue? i should also add i removed the heatsinks from the top y buffer board and the glue around the chips on the top y buffer board
                            thanks
                              Yeah, the glue around the buffer chips is vital (high voltage insulation), the buffer is probably fried now... hope the Y-sus is still OK.
                              Try with top buffer unplugged.
                              • pansatdishman
                                • Jun 2013
                                • 110
                                with the top buffer removed i get picture on the bottom half only its distortedi'm assuming thats because to work properly it needs both buffers?
                                thanks for helping me with my stupidity
                                  Yes that indicates your Y-sus is OK and your bottom buffer is most likely OK. Both buffers are required for a good image.
                                  • pansatdishman
                                    • Jun 2013
                                    • 110
                                    thanks i was worried for a second i ruined it , now it looks like i need a top buffer board for sure
                                    • rccrasher65
                                      • Mar 2014
                                      • 625
                                      I have the same LG 50PG20 -ua, I'm having power issues. I have standby(red), when I try to power set on, It goes from red to 2flashes blue, then steady blue. I have no pic or sound, but I have not tried an external source for sound, didn't think it would work if tv doesn't power up, anybody have any suggestions. checked all the voltages, all seem good. Any help would be appreciated, thanks George
                                      • Yanleb
                                        Schematic or datasheet for Plasma TV buffer chip
                                        by Yanleb
                                        I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
                                        So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
                                        Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
                                        05-18-2022, 01:36 PM
                                      • howardc64
                                        by howardc64
                                        07-24-2025, 05:17 PM
                                      • lp20th
                                        Samsung Plasma TV Power Supply Issue
                                        by lp20th
                                        I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
                                        11-28-2023, 10:28 AM
                                      • celiabrown
                                        Issue with Plasma Philips 37inch chassis FTL2.1
                                        by celiabrown
                                        Hello guys,
                                        My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
                                        Can someone has any symptom like this ?
                                        Thanks​
                                        05-09-2024, 10:56 PM
                                      • howardc64
                                        by howardc64
                                        Problem
                                        08-04-2024, 10:36 PM
