Westinghouse LD-4655VX secondary failure
+ More Options
Posts
  • jeff5may
    • Mar 2013
    • 12
    • usa
    This LED backlit LCD TV originally came to me dead. I followed this thread:
    https://www.badcaps.net/forum/showth...t=westinghouse
    The original issue turned out to be a burnt ribbon cable end that supplied power to the right half (as viewed) of the LED backlight strip. I cut a quarter inch off the bad end, shaved some plastic back to expose conductors, and reinserted the ribbon cable. The unit lit up fine, and had a pretty good picture for a lower-priced HDTV. I assembled the unit and ran it for "burn-in testing".
    Upon running overnight, the unit has developed a new failure. The screen has the same problem everywhere. Images are not bright enough, except at high brightness areas of the image. The gray areas are nearly black. White is white. When the image disappears, it persists for a short time. Moving images leave trails, kind of like the mouse pointer on a laptop.
    Preliminary troubleshooting reveals that the power supply seems OK. I have 12V, 5V, 3.3V and supply voltage for the LED sticks. Suspecting a loose tab, I pinched all the tabs around the LCD panel while watching the screen, no change in picture. I reseated the LVDS cable and the ribbon cables connecting the receiver boards. No change in picture.
  • jeff5may
    • Mar 2013
    • 12
    • usa
    Re: Westinghouse LD-4655VX secondary failure
    Freezing various parts (graphics scaler chip, lvds receiver chip, power fets, etc.) has no effect on operation.
    To me, it seems as if a cheap repair is out of reach. The timing controller boards are not available for this unit, since they are bonded with tabs to the panel. The main board is the only real board level repair option. I can do SMD repairs, but have yet to find any real service manuals or info on this unit.
    So what do you all think? Is a main board likely to repair this set? I'm not sure my buddy is willing to gamble and order a main board on blind faith.
    • jeff5may
      • Mar 2013
      • 12
      • usa
      I shot a youtube video of the set:
      http://www.youtube.com/watch?v=no2WNT5P0zY
      Are there any models nearly equivalent to this one? It has a Chimei Innolux panel in it (CMO), number V460H1-p09. Can't find a price on only one. Datasheet says the panel supports 3D and 120HZ refresh rate, so I imagine the panel also goes in some more expensive models as well.
        Sometimes tab bond faults can be located in several different places on the bond, such as the chip itself and on the LCD or PCB side. Did you try all of these? It certainly looks like a tab bond issue.
        • jeff5may
          • Mar 2013
          • 12
          • usa
          Main board tested good when rigged to a samsung monitor panel. Since the tcon boards are no longer available (and they're tab-bonded to the panel), this set is doomed to a life of endless torture on the xbox. It's big, and the kids don't care about the dark picture. Not economical to repair (new or used panel). Such a shame, ,it looked good for one night....
          • bauto601
            KDM 480W PSU upgrade succes! (opinions?)
            by bauto601
            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
            A "nice" YoungYear unit? - Badcaps
            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
            12-26-2023, 03:05 PM
          • ngml
            Repair of an LG split AC system indoor unit PCB
            by ngml
            I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
            This indicates an error in the communication between the outdoor and the indoor unit.
            The outdoor unit is fine, so the problem is the indoor PCB.
            The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
            I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
            Does anybody have the schematics of this board,...
            02-01-2025, 12:55 PM
          • nick122
            Xbox 360 PSU failure diagnosis
            by nick122
            Hi everyone!
            I recently got a bunch of 360 accessories for a good price, among which was also this PSU. It's a unit is rated for 175W (14.2A). OEM is Liteon.
            The unit briefly powers on for a few seconds, the green light comes on, and powers back off shortly after the green light changes to red. There is no output voltage, I can't hear the fan running either.
            Upon opening it up, there is nothing that would indicate why the unit failed. No burn marks, everything looks good visually. Primary cap is 130uf 450v NCC KMG, secondary caps are 1500uf 16v TAICON,...
            05-21-2023, 06:26 PM
          • nobbnobb1
            Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
            by nobbnobb1
            Hi guys,
            Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
            When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
            02-03-2022, 11:14 AM
            KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
            by momaka
            For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
            http://www.rmac.kingwin.com/products.../abt_650MM.asp
            I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful β€œspaghetti cables”.
            What mostly drew me into buying it is its 2x PCI-E power connectors...
            03-29-2022, 11:34 PM
