Vizeo plasma VP50 HDTV10A IPM of Y sus burn
  • hienton2
    • Sep 2009
    • 183
    Re: Vizeo plasma VP50 HDTV10A IPM of Y sus burn
    With chassis ground for all measurements.
    I have LM2585s
    pin1 1.7v
    pin2 07v
    pin2 08v
    pin4 5v
    pin5 5v
    R85 12v.
    • capkid
      • Oct 2010
      • 1339
      I forgot to mention that -Vy should be measured on the left side of the resistor. Is that where the 12V was read? I believe that the Y-Sus for the VP50 and the P50 are the same or similar, and dfergy54's thread has pics: https://www.badcaps.net/forum/showthread.php?p=352521
      LG Plasma Mal-Discharge Correction Service
      • hienton2
        • Sep 2009
        • 183
        Yes 12v at left side of R85.
        • robfowlr
          • May 2011
          • 3
          the top buffer board tests 0L and 1.035 (.762 from ground to ribbon connectors) bottom Y-Buffer board reads 0.0 and 0.0 , but still reads same as top for ground and ribbon cable points. here is a pic of my Y-sus board issue. any help is greatly apperciated . Rob
          • capkid
            • Oct 2010
            • 1339
            You should start your own thread.
            • ttmi100x
              HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
              by ttmi100x
              Greetings everyone,
              I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
              The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
              Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
              Upon closer inspection...
              07-31-2024, 06:36 PM
            • howardc64
              Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
              by howardc64
              Eventually discovered a burn mark near lower corner of LCD. Here is a summary
              • Backlight on, no image
              • Disconnect right buffer board (view from front), left side display comes on
              • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
              • Buffer board is pretty simple
              Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
              07-11-2025, 04:04 PM
            • Tom41
              AOC U27G3X strange burn-in
              by Tom41
              I have an AOC U27G3X 4K gaming monitor that I use both as a TV and for gaming on a Nintendo Switch 2 console. Recently, something very strange has been happening to it. After playing a game that has an on-screen timer for a few minutes, the last digit of the timer (the one rapidly flickering from 0 to 9) appears to burn in on the monitor. Going to a different source or power cycling the monitor does not help; there is a constant flickering area on the screen where that digit was.
              It seems strange that only that digit would burn in, and NOT the other digits that are changing less frequently....
              10-23-2025, 04:33 AM
            • ArMaaN376
              Samsung PS51E550 Plasma TV
              by ArMaaN376
              I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
              Opened TV cover & observed foll
              a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
              b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
              c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
              How to confirm Y -Buffer board...
              06-19-2024, 04:05 AM
            • jm1234
              Panasonic plasma TX-P42ST50 - 6 blinks
              by jm1234
              anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
              It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
              I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
              I checked that board for any obvious faults...
              05-22-2024, 06:59 AM
