Vestel Repair Please confirm these are ok
  • signup
    • May 2013
    • 189
    Hi
    I obtained some of the caps (C877, C878) required on the 17pw15/20 range and I am not sure if they will be ok and was wondering if someone could confirm, I have attached the Datasheet for the parts I have got.
    Thanks in advance
    Re: Vestel Repair Please confirm these are ok
    They are not ideal -- you really need class X. I'm not sure if class Y will work, but I don't think they will last long.
    • signup
      • May 2013
      • 189
      Cheers Tom, What is the difference between x and y all I can see on the datasheet for y is series number and class
        X is live-to-neutral rated -only-
        Y is live-to-earth rated -only-
        The use of these in unintended applications is the main reason Vestel had so many failures (trying to be cheap using cheap caps.)
        Ideally, you would use a polypropylene or poly-film capacitor, rated at least 800V.
        e.g. http://uk.farnell.com/panasonic/ecwh...?Ntt=15nf+800v
        • signup
          • May 2013
          • 189
          Right OK cheers Tom
          • signup
            • May 2013
            • 189
            Yes Tom they did work...once, turned tv on after fitting, worked fine, left it turned off for 24hours and now the TV is just starting and going straight back to standby
            • newtothis
              • Mar 2013
              • 1556
              • england
              Replace the caps with low ESR X class caps and all should be good
                There is no such thing as a high ESR X cap... they are by their nature low ESR.
                • newtothis
                  • Mar 2013
                  • 1556
                  • england
                  Something learnt
                    Also class X is not recommended, unless they are rated to a minimum of 800V ideally 1kV. Such rated components are rare, so use poly film instead.
                    • Jaime Morillo
                      Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                      by Jaime Morillo
                      Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                      The TV was stuck on the logo and I couldn't access the update menu.
                      I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                      The image result was good, but the image is inverted.
                      The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                      Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                      08-18-2025, 11:38 AM
                    • France_53
                      Vestel tv, how to flip the image?
                      by France_53
                      Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
                      05-12-2024, 05:22 AM
                    • FlailingEngineer
                      Help with Bush Tv (Vestel 17mb95m Mainboard)
                      by FlailingEngineer
                      Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                      Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                      05-31-2023, 06:52 AM
                    • dicky96
                      What 'class' is this Hill Audio DX3000 Amplifier?
                      by dicky96
                      Hi guys, this is general query really
                      So I have a Hill DX3000 3KW audio amplifier here.
                      It has a topology/design like a class A/B but all the banks of output transistors (10 transistors in each 'side' of the channel) are NPN.
                      I was wondering what class this is. It doesn't fit the description of class A.
                      It also doesn't match class A/B or B amplifiers as all the examples I see have a complimentary output stage desigs (NPN/PNP) and clearly is not G, H or D
                      I looked for 'class A push pull' but that didn't tell me anything either
                      05-04-2022, 04:20 AM
                    • massimomax
                      Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                      by massimomax
                      Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                      spero che qualcuno può averlo per riprogrammare eprom. grazie
                      Post in English !!!
                      I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                      02-28-2025, 07:27 AM
