Re: LG 50PX4R-ZB stuck in standby mode
ZSUS
BLACK PROBE ON CHASSIS & RED PROBE ON VS = 4.2 M ohms
RED PROBE ON CHASSIS & BLACK PROBE ON VS = 5.4 K ohms
YSUS
NOTHING CHANGES STILL 130 ohms
If you reverse the probes on each board, what do you read? Is it any different?Leave a comment:
Is GND-Vs measured like that on both Y-sus and Z-sus?Leave a comment:
OK GND-Vs continuity that low is bad. So you may have bad IPM or another fault on sus board.Leave a comment:
Fuses SHOULD show continuity, your reading is not normal.Leave a comment:
Hi
I think i am miles away with finding out the cause of this fault ???
I just took the fuses out of the ysus board and GND and VS+ dont show continuity , so i am presuming it is normal.
I checked the continuity between GND and VS on the power board and they also have continuity so i presume these are normal ?
On the diagram TW attached it says to take out connectors P800, P802 and P803 on the power board.
P800 is on the main av board and there is nothing connected in P803 ???
Anyway i disconnected P800 and P802 and when powered up the TV does not turn on JUST the red light and thats it ????
Thanks for any helpLeave a comment:
Forgot to mention the resistance between ground and VS+ is 130 ohmsHello Thanks for trying to help me out with my TV problem..... I have done some continuity testing on the power board and ysus and zsus.( not switched on !)
I might be totally wrong BUT i am thinking it is the YSUS board ???? The reason i say this is because i have continuity between grounds and all the vs+ on the YSUS board with the power leads and zsus lead disconnected.
Have i got a short somewhere between ground and VS+ and where do you think the fault could lie ????
Thanks steveLeave a comment:
Hello Thanks for trying to help me out with my TV problem..... I have done some continuity testing on the power board and ysus and zsus.( not switched on !)Tom, this set appears to use the same ysus,zsus as the 50PX5D. I'd have a closer look for shorts, blown fuses or symptoms on those boards and IPMs.
The initial post symptoms sounds like it could be protection mode. I don't remember all the ins and outs of the couple I had but sounds similar and I know on those you'd get a click , LED would change then back to standby in about 10secs.
IPMs replaced on both Y & Z got that junker going again and a bad Ysus was burning up resistors on the Z.
Horrible TVs to work on, the LG Fallas TV trainig guide would be close to this, but the translation to english makes the flow charts near impossible to understand.
There's a note , Unable to check voltage when disconnecting Ysus due to 50" protection?
Hi again !!
I cannot send the main board back so i am going to try and sell it on ebay !! I was then going to buy a power supply board for it ?
Thanks Tw for the protection mode diagram. I will test it out tommorow after work.
The TV defenitely makes a click sound when first turned on just before it goes back to standby, however if i turn it on again by the remote it does NOT click. It only clicks when i unplug the tv and plug back in ??
Thanks again for your helpLeave a comment:
There's a note , Unable to check voltage when disconnecting Ysus due to 50" protection?Attached Filesif you find these attachements useful please consider making a small donation to the site
Can you return your main board?Leave a comment:
OK so i need to replace the power supply board ?
I will have to try and find one !!
Thanks againLeave a comment:
I would not expect so. With bad caps you'll typically get an output voltage but it will be lower or higher than it should be.Leave a comment:
OK thanks for your help tom .... do you think it could be a capacitor problem ... ive heard that sometimes a bad cap might still visibly look ok ?? ive bought a new impedence meter but only goes to 2000uFLeave a comment:
I am not certain, but I would try that next. Unfortunately it is difficult to be certain.Leave a comment:
do you think that this indicates a faulty power supply thanksLeave a comment:
Yes .... when the tv is first powered up then by pressing the power button on the remote.
If i try pressing the button on the remote again it does not click ONLY when unplugged and plugged back in ??Leave a comment:
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
Assuming...7 Photos -
by duwaneHi All.
I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to... -
by AleMontiHi everyone,
I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
After checking the basics I did the following:- I measured all voltages and as expected the only active supply is the 3.5V standby. It
Then today it randomly sprung to life like a zombie but shortly died thereafter. I have no idea why it would have done that and its the first time I've seen it running. I discharged capacitors on the board last night, then it was sitting today.... - Loading...
