Olevia 242-s11 firmware
  • Twithers
    • May 2013
    • 69
    • U. S.
    With this Olevia 242-S11 I just got up and running, how would I update the firmware? If I have no problems with the TV at all, what would be the advantages, if any, of updating the firmwre?
    Thanks.
  • zklgfs
    Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
    by zklgfs
    I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
    08-11-2025, 02:14 PM
  • wattage
    by wattage
    Hello Badcaps Community,
    07-13-2025, 04:41 PM
  • merravid
    Updating Firmware on Toshiba 65X9863DB
    by merravid
    I have a flashing green/red light on this model which then goes to fixed red. No display whatsoever. Voltages at the power supply look OK, so I'm guessing it is a motherboard/firmware issue.
    I've downloaded the firmware for the model and serial number which contains three files:
    mb130_en_bin.gz
    mb130_PM51_connected.bin
    mb130_RomBoot.bin
    usb_auto_update_g10.txt
    Looking at the script file, it look like it wants mb130_en_bin.bin, which is inside the .gz, so I'm guessing I need to extract that before trying to flash?...
    12-01-2022, 03:35 AM
  • sikocan
    NP930XED Samsung Galaxy Book2 Pro Laptop PD Firmware Loop
    by sikocan
    I hope this message finds you well. I wanted to share a recent experience I had with a laptop that had a Type-C Port issue, specifically related to a PD (Power Delivery) controller problem. After replacing the damaged PD controller chip with a new one I purchased from AliExpress, the laptop now charges properly and negotiates power as expected, allowing the device to power up. I've replaced this chip twice just in case.
    However, it seems that the laptop's BIOS is detecting an older version of the PD Firmware on the newly installed chip. As a result, it attempts...
    01-11-2024, 01:47 AM
  • Daniel Larsson
    Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
    by Daniel Larsson
    My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
    I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
    During these seconds the function button is not working...
    08-13-2025, 10:29 AM
