Sharp Aquos LC42D43U-42 Has Sound but No Picture
  • jjakatw
    • Jun 2013
    • 13
    • United Stated
    I have a Sharp LC42D43U-42, that has no picture but has sound. Read somewhere that it may be the main board so we switched it out, now the tv comes on, blank screen, green power light and green opc. We read that maybe we need to upload the software for the new main board, but can't find anywhere to download the software so that we can perform the upload to the new main board. Does anyone know where we could find that? Also what is the thought that the main board was not the problem, and that it was the backlight inverter? Prior to changing the main board the tv would come on gray and fade to black, no picture what so ever. Any help or suggestions are appreciated. Thanks.
    Re: Sharp Aquos LC42D43U-42 Has Sound but No Picture
    If the TV had sound I would be considering inverter or T-con. Was the screen lit up with old board?
    • jjakatw
      • Jun 2013
      • 13
      • United Stated
      Thanks for the quick reply. The picture before the main board was changed was gray fading to black. Now with the new main board, the screen stays lit, more of a dark blue than gray or black, but still no picture. We did switch the inverter, but switched it back, as the one we received we got off ebay and it looked burnt.
        Sounds like a t-con or panel issue. Can you post pictures of inside your TV?
        • jjakatw
          • Jun 2013
          • 13
          • United Stated
          I have attached a few pics.
          • jjakatw
            • Jun 2013
            • 13
            • United Stated
            A couple more of the backlight inverter...
            • hienton2
              • Sep 2009
              • 183
              I have one like that. Problem is panel , Try to play with scan board on top of tv.
              Right side of tv look from front.
              • jjakatw
                • Jun 2013
                • 13
                • United Stated
                Scan board? Sorry just learning this stuff and not sure what that is. Is that the board that the tabs are attached to? Should I remove the the outside frame to check this?
                • hienton2
                  • Sep 2009
                  • 183
                  It takes more work to remove the outside frame . Just cut the black plastic cover
                  the board then hair dryer to the board . It makes some affect the tab bond ribbon to see any change on screen. Then you know what is the culprit.
                  • jjakatw
                    • Jun 2013
                    • 13
                    • United Stated
                    I am guessing you are saying it may be a bonding issue? Not a board issue?
                    • jjakatw
                      • Jun 2013
                      • 13
                      • United Stated
                      On another note...because I installed a brand new main board...where can I get the software/firmware to update the board for this tv?
                        I have a 26" Sanyo (rebadge) using a Chimei panel, which has tab bond issues. Sometimes all you will get is a dark (no image), lit up screen, with a dark blue tint. Other times you'll get a faded light grey screen which slowly changes colour.
                        Different fault. Same cause and fix:
                        https://www.youtube.com/watch?v=purk_SyiT44
                        • jjakatw
                          • Jun 2013
                          • 13
                          • United Stated
                          Tom...I have watched that video before...do you think that this Sharp has a similiar issue then?
                            It would be one thing to check, as the symptoms are similar to other tab bond faults. Sharp panels (like in your Sharp TV) rarely have tab bond faults though. Not unheard of, but rare. Since the swap of the main board changed the symptoms, I would not rule out a main board fault. Possibly the replacement main board is bad too, given they are usually pulls from scrapped TVs.
                            • jjakatw
                              • Jun 2013
                              • 13
                              • United Stated
                              The main board I bought was suppose to be brand new unused. Do you think I need to update the software/firmware in order for the main board to work correctly?
                                I would doubt this to be the case, but was the board from the exact same model?
                                • jjakatw
                                  • Jun 2013
                                  • 13
                                  • United Stated
                                  It was suppose to be for the same exact model, and was suppose to be brand new unused. The part numbers on the board say the same part numbers, but what I have read online says this board may need software updated after installation.
                                    It's worth a shot, I guess -- can you do it via USB?
                                    • jjakatw
                                      • Jun 2013
                                      • 13
                                      • United Stated
                                      I want to...but I can't find it anywhere online. Any ideas where I could find that?
                                        You can try contacting Sharp tech support and they may supply you with files and instructions. Does the TV have a USB port?
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
