Dell W4200HD repair
  • bklein
    • Nov 2010
    • 7
    Dell W4200HD repair
    I've been trying to repair a neighbor's plasma set. The power supply board LJ44-0068A had bad (leaky) electrolytics 1000uf 250V and 330uF 450V. I replaced them but still bad - hear relay click on remote ON press, no VA or VS supplies. I bought a replacement PS board off ebay. Tried it and still no VS or VA. Discovered a blown F8003 fuse. Replaced it and tried it. R8009 got red hot and cracked. Fuse still good. Now I don't know if the ebay board was bad from the start. Why no VA or VS supply output? Was I supposed to try the new board with loads unplugged first for good VA/VS?
    Re: Dell W4200HD repair
    Where is R8009? On power board?
    Have you tried powering set up with Y-Main or X-Main unplugged?
    • bklein
      • Nov 2010
      • 7
      I had tried the 2nd board completely installed and the resistor fried. I sent that back for a refund. The original board has the new caps and no known bad components but no VA etc. I'm hesitant to try another ps board.
      • bklein
        • Nov 2010
        • 7
        I bought a 2nd power supply board and it didn't work either. Doesn't output high voltages if targets unplugged. Took the set to a repair center. He tried his power board and same result - no HV. So he says it is the auxilliary smaller PS board but didn't have one to try. I bought one off ebay and it is on its way - but I have my doubts....
        • bklein
          • Nov 2010
          • 7
          Turns out he was right. So it required both the main power board and the auxiliary to work... Bizarre.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            Glad you got it fixed and thanks for the report.
            A working TV? How boring!
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • master3112
              by master3112
              07-29-2025, 01:55 PM
            • Garret Matt.
              DELL Latitude 5430 Rugged CORE_D5K Rev.A00 Schematic and/or Board View
              by Garret Matt.
              I'm Working on replacing an Inductor on this Dell's board and I need to come up with a compatible replacement. As much as I would like to smash a comparable 2R2 in the same spot I'd like to confirm the specs before confirming a killed board. For my purposes I'd be happy with a second opinion on the replacement inductor or the actual schematics/board view. As this is a commonly used Dell Rugged in my local service area, schematics would greatly help in the future.
              Thank you in advance for any assistance you can render.
              Inductor In question. Buzzes like...
              06-20-2025, 01:21 PM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
