Digitrex CTF4071, Sound but no picture
  • Andyd1970
    • Feb 2013
    • 374
    • united kingdom
    #61
    Re: Digitrex CTF4071, Sound but no picture
    Hi Tom,
    I have dismantled the bexel, the lcd unit and removed the white plastic sheet over the bulbs, now with the PSU and main board still attached and the TCON attached but no connection from the TCON to the LCD panel I switched the set on and ALL the bulbs illuminate for a second of two and then switch off.
    Does that mean the bulbs are OK? could it be a transformer fault?
    Andy
      Sounds like a transformer or inverter fault, usually with a bad transformer you would see some dimmer bulbs though so you may have something more common like that low 12V line previously mentioned.
      • Andyd1970
        • Feb 2013
        • 374
        • united kingdom
        #63
        OK, well it was a good experience dismantling the TV completely, so how should I test the transformers/inverters? Or is it time to just replace the PSU/Inverter?
          I would give replacing the PSU board a go, but try to get a returns policy just in case.
          • Andyd1970
            • Feb 2013
            • 374
            • united kingdom
            #65
            Hi Tom,
            The PSU/Inverter arrived and was fitted today and touch wood it has been running for a good hour or so and have sound and picture.
            Thank you so much for your help, is there anyone that buys the PSU/Inverter faulty?
              Some might but you'd probably only get scrap copper cost for it. A few quid...
              • ZenYorks
                • Jul 2013
                • England
                #67
                Hi AndyD1970 I am having the exact same issue and i want to change the inverter, how did you get to the inverter and how did you change it? all help would be appreciated!
                • TR103
                  by TR103
                  - it keeps rebooting
                  01-22-2025, 04:12 PM
                • Mgiffune
                  by Mgiffune
                  06-09-2024, 10:28 AM
                • Ierwin
                  by Ierwin
                  05-13-2025, 03:31 PM
                • jchang
                  Samsung UN70NU6900F no picture and no sound
                  by jchang
                  Hi all
                  I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                  Symptom:
                  No picture no sound.
                  When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                  No sound at all.
                  What I tried:
                  1. I tried unplugging the left or right ribbon...
                  01-09-2023, 06:28 PM
                • ChaosLegionnaire
                  by ChaosLegionnaire
                  09-13-2022, 09:02 AM
