Sony logo flashes on then off with 6 blinks. Anyone have a service manual for this?
Sony KDL-40S504 6 blinks
Tags: None
Re: Sony KDL-40S504 6 blinks
I believe 6 blinks is a backlight error, if that helps.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
Tried a firmware update first via USB, that worked but still same issue. Guess Ill have to delve into it..Comment
Sony do usually have INVERTER ERROR feedback -- you may be able to disable this to clear 6 blinks & check for 2 seconds to black, or other fault.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Look at the pad with 'FB' with the DC meter > 2V = bad, should be 0.1V. Watch to see if the meter jumps fast to see it.
The picture is from 40" Samsung.
http://s807.photobucket.com/user/bud...tml?sort=3&o=2Last edited by budm; 06-10-2013, 11:52 AM.Never stop learning
Both FB pins never move off 0V from power on to shut down and blinking.Comment
Found another connector on the other side of the PS board, that goes to main board.
Has an INV_ERR which stays at 0v, and
a BALANCER_ERR which jumps up to 8V when backlight comes on..Comment
You have a BALANCER_ERR then. Is this on the balancer board anywhere?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Oh is this the inverter board? That board only has high voltage connection, and then VCC, FB, GND, and LD.
What's the difference between a INV_ERR and BALANCER_ERR?Last edited by kevinm34232; 06-10-2013, 01:18 PM.Comment
This TV has a balancer board for distributing the high voltage AC, instead of an inverter board which steps up 24V to high voltage for each bulb.
A balancer error would probably be on the balancer board, whereas inverter error would likely be generated by the power supply board (the HV step up.)
There is a 1-xxx-xxx-xxx number on the power board, I may have a schematic. Can you read that off?Last edited by tom66; 06-10-2013, 01:27 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
The PS is
Sony A-1660-720-B IP1 Board
Board Numbers
1-878-598-11
1-878-598-21
http://www.shopjimmy.com/sony-a-1660...wer-supply.htmComment
I have the -11. No -21 though.
Where is CN1004?
The signal LD on CN6701 to the balancer is used to control BALANCER_ERR. If LD goes low, it turns on Q6706, which pulls BALANCER_ERR high (to 12V)Last edited by tom66; 06-10-2013, 01:38 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
If I remember correctly, the Balancer error (FB) is for detecting if each lamp draw too much current. The Inverter error is for detecting the failure of the Inverter circuits which drive the high voltage transformer on the inverter/power supply combo board.
Thanks for the diagram, TOM, I try to trace out the connection using Shopjimmy, it is not too good.Last edited by budm; 06-10-2013, 01:58 PM.Never stop learning
CN6701 is the connector on the PS board that connects to this balancer board. The LD goes low each time back light flashes on (2x). When backlight goes off, it returns to 12v.Comment
So are we thinking it's the inverter board, or possibly a bad bulb?
There's not much to it I checked the all the diodes and resistors all seem OK, I measured each transformer got these results:
T101 - 144.9
T102 - 146.8
T103 - 143.7
T104 - 145.7
T105 - 145.1
T106 - 147.9
T107 - 145.6
T108 - 145.9
T109 - 144.9
T110 - 148.1
T111 - 144.8
T112 - 144.6
Anything look outta whack?Comment
They look fine.
Can we get a picture of the bottom of the balancer board?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Which side, on that bottom picture, is the connector with LD etc. on it?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by matwanHello,
I have problem with SONY 55X90J. After several check status is as below;
1. Running power board as stand alone:
TCON_12V =~ 12.6V
EVDD V On Max 24V= 19V.
2.Running power board with TCON as stand alone:
Effect as below, attched.
3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
"I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
Best regards.... -
by GoodCapDudeHi everyone. First post on Badcaps!
I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot.... -
by odie34I am a hobbyist (not a professional) so please be gentle...
I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,... -
by reassorHi.
Power is ok
Tv turns on by it self when you turn IT off with button or pług.it shows sony logo the android logo but with like 1 frame every 10 sec. Music starts after like 1 min. After some time logo will Just hang. But i can turn volume up and down on a pilote but its very slow as well.
Should i force update? If so how?
I did reset.
Mainboard Looks pristine.
Very wierd. -
by IhandyrepairHI guys
I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
here is the issue
I have Sony and android logo. but then 4 led red flash lights front of the tv
I have 3.3v ref. 12v reg then T con 12v when I press the power on button
but then I get black screen and 4 red flash light at the front LED
but I get 3 led flash on the LED driver board.
I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
so I tried... - Loading...
