Just picked this up with problems. When it is plugged in, it clicks and the backlite comes on. The power switch has no effect. It just comes on and stays on. There is no sound or picture. All power supply voltages are present and clean. TCON has 12V on both sides of the fuse. Main Board? I did check the 3 pin regulators, and they all seem ok.
Samsung LN-T4661F problem.
Re: Samsung LN-T4661F problem.
Check for blown fuse on the T-CON board. Re-seat the LVDS cable, check the voltage on the T-CON TEST POINTS.
Similar to this one:
http://s807.photobucket.com/user/bud...?sort=3&page=1Last edited by budm; 06-07-2013, 09:09 AM.Never stop learning
These are notorious for the caps failing in the top right corner of the power board. Even if yours are good I would replace them while youve got it open. as I recall 2 2200uf 10v and 2 1000 uf 25v. you might get lucky and find they are causing your problem as well, although it sounds like your problem is elsewhere.Last edited by Caleb; 06-07-2013, 09:45 AM.Liberating magic smoke one part at a timeComment
Can we see the pictures of the T-CON board?Never stop learning
I have already ordered fm/fc series caps from digikey even though with clean power supply voltages (checked with my oscope). Here is a picture of the tcon. I found one for $16 with a 30 day warranty so I ordered it.Attached Filesif you find these attachements useful please consider making a small donation to the site
by THXFXHi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
I check capacitors and diodes and didn't find any short IN MAINBOARD.
Measured all power supply... -
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by howardc64Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable... -
by alro7779Hello, everyone!
A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,... -
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
- Loading...
