Hi all. I got this TV to have look what is wrong with it and it looks like image displayed on LCD is darker on one side. When TV is cold image is fine, but after few minutes this weird thing happens. My question is: Is this LCD panel or is that a backlight problem?
Sony KDL-40W4500 image problem
Tags: None
Re: Sony KDL-40W4500 image problem
When this effect occurs does the left hand side blur considerably more? That is, if you were to move the Xbox menu would you see a long delay before the ghost image cleared?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
On sony 40" TV's with bad tab bonds, applying pressure to the tab usually doesn't help, so the set is considered "unrepairable" there is a technique that I got to work for a few hours where you solder a resistor from a thin board to one of the tabs, but it requires delicate precision / and good soldering skills. It's probably worth a shot if your skilled, but I personally am not even good enough to get the soldered resistor to stay attached to the tab, which is why the fix only lasted for a few hours for me.Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.Comment
I didn't give it 100% of my effort / time. I could possibly have also used a conductive adhesive (is arctic alumina conductive?). Pretty much after I put it back together and it stopped working after 5 hours I just put it in a box and haven't touched it since, stripping the set down to the panel is a chore... for all I know the wire I used might have just grounded out to the frame somewhere, I had to wrap the wire in electrical tape to try to prevent that.
You really need to find yourself a 32" or 40" sony with the ghosting tibi, I can tell you really want to try that resistor fix
by rimwallThis TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or... -
by ChrissygizmoHello again everyone,
This is my latest mission, to try getting this Sony tv back to normal working order…
I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried... -
by crackedprintI have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
I have tried a Cold Reset as per the service manual.
I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
I have looked all the way through the service manual and tried many online...-
by retrorepairHello gurus, hope you can assist me...
I have a Sony KDL.40P3600, with an issue on the left side of the screen (pictures attached).
I think the problem is the panel, but before send it to trash, i would like to get a second opinion.
Thanks in advance.2 Photos -
by NSkyLabI though I've seen all possible kinds of failures but this one is new...
Colors saturation is gradual.y fading out on the left side of the screen (all colors are fading out). While B&W image is looking good.
I tried replacing TCon but nothing changed. So this is looking like the panel failure. Is there a chance it can be fixed?
Any useful measured can be done on the panel's narrow pcbs? Is there may be something similar to taping trick to fix this issue?... - Loading...
