panasonic lcdTH-L32C20M
  • willyam1
    • Feb 2012
    • 112
    • israel
    HI to all.
    problem is by powering red stb led become green and then click and red led again and it blinks 10 times.
    is it the pfc section in the p.s the problem .
    p.sTNP4G469.
    MAIN-TNP4G466.
    WILLYAM1
  • willyam1
    • Feb 2012
    • 112
    • israel
    Re: panasonic lcdTH-L32C20M
    anyone?help..........
    willyam
    • Andre Gilbert
      by Andre Gilbert
      11-20-2024, 08:52 PM
    • jm1234
      Panasonic plasma TX-P42ST50 - 6 blinks
      by jm1234
      anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
      It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
      I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
      I checked that board for any obvious faults...
      05-22-2024, 06:59 AM
    • CrewmanRedShirt
      Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
      by CrewmanRedShirt
      Hello all,
      As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
      07-13-2024, 11:02 AM
    • nobbnobb1
      Panasonic TC-P50U50 Powers Off - 8 blinks
      by nobbnobb1
      I have a Panasonic TC-P50U50 plasma TV which powers on briefly, then powers off and flashes the power light with 8 blinks. This TV is infamous for this, of which the suggestion that the SS board has failed due to loose grounding screws and requires a replacement of the following components on the SS board:
      2x DG302 (Q16051)
      2x RF2001 (D16041)
      2x 5.6 ohm SMD resistor
      1x BD8694 IC
      I have already gone ahead and replaced these components, as well as cleaning off the ground connections on the SS board as well as the associated...
      03-21-2023, 08:33 PM
    • Biruslapio
      Panasonic P50VT20B Plasma 12 Blinks, Power Supply or A-Board?
      by Biruslapio
      Hello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
      It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
      It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up...
      02-16-2021, 09:44 PM
