DMTech LU20XT TV/DVD couple of faults
  • notallbad
    • Oct 2012
    • 1183
    Tv appears to function correctly in all aspects ATV, DVD player, Menu etc.. and on all accounts has quite a decent picture, so works except for the following:
    Firstly, the keypad not functioning 100% correctly. Volume up and down works fine all the time but the DVD eject button does not work instead the Stop button open and closes the DVD tray. And the Menu button does not work, instead Menu is accessed by the Program Up button.
    Secondly, although the analog tuner (ATV) will attempt to tune in, of course analog no longer exists but at least the function works however when DTV is selected the Settings option is greened out in the Menu options so it is not possible to tune in digital channels.
    It says 'DTV Booting. Please wait' when switching on the Tv when DTV is selected, then displays DTV top right hand corner but the screen then just goes blank (black).
    I have accessed the Service Menu and done a reset via the 'Reset' option which does put user settings back to default and selected the 'Eeeprom' option but it does not go back to first setup on re-power as would be expected so that I can select language, date/time, tune ATV and DTV channels etc..
    Theres also an option in the Service Menu 'DVBT' which is selected to 'ON', this I would of thought could be toggled on and off but NO.
    Also I can not access the DTV W.Bal option but can select PC W.Bal and make adjustments, nor can I access the Control option whatever thats for!
    Any thoughts?
    I have a gut feeling its the Eeeprom but would be grateful for any ideas to go forwards with this one.
  • notallbad
    • Oct 2012
    • 1183
    Re: DMTech LU20XT TV/DVD couple of faults
    Details relevant to this particular make and model.
    Service Menu accessed via remote, I don't have the original so using a universal remote and it works for the basic functions needed i.e volume, channel mute
    On this remote I pressed
    1-/11 also labelled 11
    1
    1
    2-/12 also labelled 12
    This then displays the Service Menu with just a few options.
    Reset
    Eeprom
    Text
    Language
    Country
    Hotel Mode
    Heatrun
    DTV W.bal
    PC W.bal
    Bus Stop
    Control
    DVBT
    Panel LG20. SDB1
    Tuner SSPG40B
    2006-10-27-2820
    Another detail is that this model does not have its own internal PS b/d but in fact runs from a 12V DC power pack which is a nice feature as the TV can be run direct from a 12v car battery, handy for camping etc. The only downside is the unique design of the dc jack connection, its a round 4 pin connector so you have to buy from select retailers at a high price however I chose to solder on a 2 core wire direct to the Main A/V board with a standard dc jack 2.1mm or something and can use either a standard car cigarette lighter lead with a dc jack on the other end or in doors use any 240v to 12v 5a power blocks.
    • notallbad
      • Oct 2012
      • 1183
      So to enter Service Menu from original remote:
      Display
      1
      1
      Line
      • notallbad
        • Oct 2012
        • 1183
        Is it possible that there is another Service Menu? Extended SM?
        I suspect either the fault lies within the Firmware Eeprom (H/W or S/W corrupt) or the Digital tuner board is faulty.
        • kandj1@talktalk.net
          • Sep 2015
          • 7
          Hi
          Did you ever get your problems with the DMtech solved? I have an LQ20X TV/DVD, so although not exactly the same model I do have similar problems, i.e. the Stop button open and closes the DVD tray; Menu is accessed by the Program Up button; when DTV is selected the Settings option is greened out in the Menu options so it is not possible to tune in digital channels; It says 'DTV Booting. Please wait' when switching on the Tv when DTV is selected, then displays DTV top right hand corner but the screen then just goes blank (black).
          Initially my set wasn't working at all, but then I found 2 blown capacitors in the separate power supply. £1.18 later and it burst into life - result! or so I thought. It's DVD player won't read discs even after I've cleaned the laser 'eye', and I've got all the problems you had PLUS I haven't got a remote control or user manual. (I'm using the buttons on the right of the set)
          I know many folk would have ditched it by now, but now I've got life back into it I'd love to see it fully operational. You know the feeling.
          Thanks in advance for any help.
          Keith
            LCD LED TV Service Menu Codes
            TCL LED TV Service Menu Code
            LG LED TV Service Menu Code
            10-31-2024, 03:58 AM
            Acer TravelMate P2510-G2-M-54Q3 + Option Pack Notebook P2 Specification for Upgrade or Repair
            This specification for the Acer TravelMate P2510-G2-M-54Q3 + Option Pack Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P2510-G2-M-54Q3 + Option Pack boardview and P2510-G2-M-54Q3 + Option Pack schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
            09-06-2024, 08:00 AM
          • sohail5307
            I need how to open this Dell service menu option in dell latitude e6420
            by sohail5307
            I need to open service menu of Dell laptops like image in attachment
            Ignore my English
            I want beacause i flashed mec5055 using rt809h now it's does not have service tag, but when I install service using F2 in bios setup after save service tag and press disable manufacturing mode using alt+f then battery chagring is permanently disabled. I want to resolve this problem...
            01-13-2023, 05:56 AM
          • Retro140
            Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
            by Retro140
            So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
            To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
            06-18-2023, 06:13 PM
          • reformatt
            Windows 11 Start menu/Taskbar hanging
            by reformatt
            Couple of Windows 11 machines have come in this week with the same issue. After you login, the taskbar will not appear (or just be a black bar). No access to Start Menu. Task Manager (use CTL+SHIFT+ESC) works, however the Performance stats seem stuck with CPU on 100% for Task Manager itself. Trying to exit Task Manager result in it hanging as well. No issue if you boot into Safe Mode.
            First machine, tried many things to no avail (System Restore from last Windows update, rebooting in Diag mode, trying to reinstall Windows Apps via Powershell). In the end, I did an in-place upgrade...
            04-23-2024, 10:16 PM
