Not as lucky as I'd hoped, Westinghouse LD-4255VX
  • johnboy1313
    • Nov 2012
    • 1959
    Re: Not as lucky as I'd hoped, Westinghouse LD-4255VX
    Looks like I dropped the ball on getting that T-con picture. At any rate, I found a cheap mainboard on eBay. The set is working now. The sound on this thing sucks. My cell phone has better audio.
      Glad to hear. Most LED TV's sound sucks, they are way too thin.
      • zesko
        xps 9520 ribbon cable
        by zesko
        I have a XPS 9520 with broken daughter board and missing ribbon cable. I can fix the board by replacing the connector, but I can't find the correct ribbon.
        There is 2 models, idk which one is needed on my laptop.
        0xkvng
        00vpr2
        Daughter board is LS H822P. When I check for a palmrest, the board attached to have a 0xkvng ribbon. But when I check for LS h822p, it's 00vpr2 ribbon...
        Someone can help me with that please ? Idk the difference between these 2 ribbon but they definitely doesn't look the same..
        thanks...
        10-23-2025, 05:03 PM
      • Tr0ll
        by Tr0ll
        Original T-con:
        First replacement T-con:
        10-07-2023, 07:48 PM
      • Rubenlily
        Quick question about the ribbon
        by Rubenlily
        Hey,
        So I have horizontal lines on my TV and I'm trying to trouble shoot. My question about the ribbon is:
        When I disconnect one ribbon from the t-con I should get half picture working and other half black or something like that correct? But when I disconnect the ribbon on one side I just get a dark screen and it doesn't matter what side I disconnect. I just get the dark screen. No half working, no one half black and the other one left. Sound is playing from the TV so it's obviously on and when both sides are connected I have the picture with the horizontal lines...
        08-17-2023, 11:09 AM
      • Scincidae
        UN70NU6900FXZA Won't Boot Unless I Temporarily Disconnect Right LVDS Ribbon
        by Scincidae
        I recently was given a UN70NU6900FXZA that would only boot loop once plugged in (auto powers on when plugged in). I found that disconnecting the lower (right side) LVDS ribbon, then plugging the TV in, followed by reconnecting the lower LVDS ribbon will allow the TV to work 100% normal as far as I can tell (no lines, no discoloration, no dimming or anything like that).
        I tried the tape method on the lower LVDS ribbon and found that if I cover pins 10 and 11 (counting from the bottom up) allows the TV to boot normal but 25% screen all the way to the right side is discolored. While...
        04-24-2022, 06:00 PM
      • kca
        50" LG tv with a slightly torn ribbon cable ~ Any repair method?
        by kca
        Hello all ~
        I have this LG 50" plasma tv that is in perfect working condition except for the fact that it has one (and only one), singular torn ribbon strip on one (and only one) of the 8 orange ribbon connectors that feed from the Y-Sustain to the screen itself.
        So, as a result, there is one, singular thin black horizontal line that goes across the entire screen. Distracting enough to render the picture unwatchable for all intents and purposes.
        What I am wondering is if anyone out there has ever had any success in fixing one of these ribbon cables...
        09-24-2020, 02:07 PM
