BUSH LED2497ODVDFHD, 17PW80 V2, Dead!
  • Andyd1970
    • Feb 2013
    • 374
    • united kingdom
    Hi Guys,
    Through all the great help for you guys especially Tom66, I have learnt alot about fault finding TV's. But have my first one that is totally dead!
    It contains a 17PW80 V2, with the very long caps, I cannot see any leaking or domed caps. Any suggestions guys?
    Andy
    Re: BUSH LED2497ODVDFHD, 17PW80 V2, Dead!
    Here's the schematic.
    http://www.tgohome.com/ServiceManual...h=Submit+Query
    So, they use 22" power supply in 24" LED, makes sense...
    Test voltages on PL703.
    • Andyd1970
      • Feb 2013
      • 374
      • united kingdom
      Hi Tom,
      Thank you for info, I take it as from my old memory pin 1 is denoted by a small black dot on the PCB for PL703?
      If so I have nothing on pin 7 and pin 9 and only -170mv on pin 11. That was measure with the PSU connected to the TV.
      Andy
        Check voltages across: C279, C730, C731, C734, C735, C775; any which are not present ignore for now.
        • Andyd1970
          • Feb 2013
          • 374
          • united kingdom
          Hi Tom,
          Sorry for the delay, have been so busy
          See below the following readings:
          C279... 0V
          C730....0V
          C731....0V
          C734....Not present
          C735....Not present
          C775....Fluctuation of readings from MV to about 32v
          Andy
            OK, check of which present:
            D708, D709, D710, D712, D713, D715
            for shorts (diode test, both ways, in circuit.)
            And voltage across: C715 (On primary), C705 (400V cap) very carefully
            • Andyd1970
              • Feb 2013
              • 374
              • united kingdom
              Hi Tom,
              Details Below:
              D708...S/C
              D709...S/C
              D710...S/C
              D712...OK.... 0.430V/0.823V
              D713...OK... 0.430V/0.823V
              D715... Not present
              C715...11.8V to 15v ish
              C705...326V
                Remove each of D708, D709, D710 and test out of circuit for shorts. You can briefly run the set with whichever diodes are still good. (One or two, max one minute running time.) CRAPPY VESTEL parallel three diodes. If one diode gets slightly hotter than the other two, it ends up taking more current than the others, causing it to heat up more, causing it to take more current.... I'm sure you can see this cycle will eventually lead to a diode failing. Built to fail!
                • Andyd1970
                  • Feb 2013
                  • 374
                  • united kingdom
                  Hi Tom,
                  Sorry for the delay in replying, I have followed your advice and found D710 was short, the other two were fine, so I removed D710 switched on set and it worked OK Fantastic and I am certainly learning about the crappy VESTEL PSU's!! Just need to buy a replacement diode, can you recommend a good supplier as dont want to use Maplins after your warning last time The info on diode is:
                  SB5100 PEC1289
                  Andy
                  • Andyd1970
                    • Feb 2013
                    • 374
                    • united kingdom
                    Hi Tom,
                    Just checked the circuit diagram and it shows UF5402 below D710. Just dont want to buy from a crap supplier, would it be best to replace all three?
                    Andy
                      Unlike capacitors, counterfeit/dodgy UF5402's are very rare.
                      http://www.ebay.co.uk/itm/UF5402-DIO...item5ae710d75c
                      should be OK.
                      Maplin are fine for them too, but they don't stock them. They're nearly useless -- apart from a few lucky hits. I'm not sure why they bother at all.
                        I would also suggest you purchase thermal epoxy to stick the diodes together and make sure they run at the same temperature. It would also be advisable to replace all of D708-D710 with a new diode from the same order, to ensure they will have closely matched specifications (same batch of silicon.) The design of this power supply is bad in the first place, there's not much you can do unfortunately.
                        • Andyd1970
                          • Feb 2013
                          • 374
                          • united kingdom
                          Hi Tom,
                          Thank you for the advice I will buy all three and get some thermal epoxy.
                          You are a star!! thats another TV you have saved from the dump
                          Andy
                            Use the epoxy for 24V diodes too.
                            I have considered picking up some smaller Vestels for sales to students. 24" is ideal for bedroom etc. And they are often easy to fix due to the cheap components used.
                            • Andyd1970
                              • Feb 2013
                              • 374
                              • united kingdom
                              No problem I certainly will do. Well they certainly are welll laid out inside and easy to repair from my experience
                              Thank you for all your help.
                              Andy
                              • mutttt
                                • Dec 2013
                                • Ireland
                                Thanks guys I had the same diode problem
                                • satinser
                                  • Oct 2012
                                  • 214
                                  Many thanks I too had same problems changed all three to make sure.
                                  • PatM
                                    • Sep 2013
                                    • 3
                                    Reading this at work today :-) and searching Vestel 17pw80- I smile because Ive just started to work on one of these. The 22'' set is DEAD and I obviously went for the PSU straight away- finding the usual stick caps ok- surprise, then the diode short, which I duly replaced with another like-minded soul from another trashed Vestel board- but still DEAD, not LED on the front of the set- nothing. Any pointers as to what's been fried by passing a/c over it? Theres a guy on ebay selling a kit of 3 components to fix this board but I doubt 3 will fix it as Ive looked at the obvious (ive got the inline fuse shorted at present, as I managed to blow that while testing... I can buy a board for £50 but that makes short work and an expensive repair. I too have the schematic, but stopped short of measuring voltages as it was so cold in my workshop last night!
                                    • flocko
                                      • Nov 2012
                                      • 1121
                                      I have repaired 5 or 6 of these boards and have only ever seen the Diodes go bad you need to pull them all and replace all 5 with new then it should work, and do as Tom says use thermal epoxy to hold them together and leave the legs long Flocko
                                      • PatM
                                        • Sep 2013
                                        • 3
                                        No, the other 2 diodes where ok- but Id managed to solder a duff joint on the fuse Id shorted out with a scrap of old wire off a resistor- Doh! Wondered why I had no output /reference voltages. Its usually something simple! That set is only just a year old and cost me £34 off Ebay- it will do my garage a treat and its got a DVD built in. Feel a bit sorry for the young couple I collected it from.
                                        • PsiDOC
                                          BUSH 42" LED TV. BLED42FHDAE Completely dead. Diagnosed and solution awaiting parts..
                                          by PsiDOC
                                          HI all. Just a note for anyone that has one of these TVs.
                                          Make: Bush (China)
                                          Model: BLED42FHDAE.
                                          Symptoms: Half screen went dark, then tv wend dead. No power lights. Fuse checked ok.
                                          First thing checked was standby 5v: Present @ 5.1v.
                                          PS_ON signal from main board: Present @ 4.5v.
                                          I suspected the power supply to be in a foldback / crowbar condition after the screen going out, so I disconnected the power to LED Backlight board (Part ER643). Now standby light is on and TV responds to remote power on - light goes green.
                                          Disconnected the LEDs from the...
                                          10-30-2021, 05:22 AM
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
                                        • zunasthegreat
                                          Chieftec GPS-450-AA with dead 20N60C3
                                          by zunasthegreat
                                          Hello everyone hope all doing well!
                                          I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                          09-01-2024, 07:12 PM
                                        • FiguringITout
                                          MSI Raider GE75 - Not posting, probable dead CPU
                                          by FiguringITout
                                          Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                                          Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                                          07-25-2024, 07:27 AM
                                        • FlailingEngineer
                                          Help with Bush Tv (Vestel 17mb95m Mainboard)
                                          by FlailingEngineer
                                          Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                                          Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                                          05-31-2023, 06:52 AM
