BUSH LED2497ODVDFHD, 17PW80 V2, Dead!
  • oddbodd
    • Mar 2013
    • 121
    Re: BUSH LED2497ODVDFHD, 17PW80 V2, Dead!
    Originally posted by wil71
    Hello guys great reading. I have a jvc lt24dg42j which is dead and uses the same power board (which also is dead), I have ordered the caps but was wondering about the epoxy paste, I take its the same stuff as used on processor heatsinks, Can you explain how this would be used please to a newby who likes experimenting.
    I only had some of the thermal paste for CPU heatsinks, so used that.
    It has to be better than nothing.
    • oddbodd
      • Mar 2013
      • 121
      Since the repair, I've tried to use the TV as a PC monitor [VGA connection], but the picture flashes rapidly. It was working OK in TV mode. I've tried different refresh rates, but nothing stops the flashing.
      I shall test with an HDMI cable when I have one, but now it's started flashing in TV mode as well. It sometimes stops after a short while with a decent picture, but changing some of the TV settings will start it off again. The rate of the flashing depends on which setting is been changed.
      Could it be anything to do with the repair? Should I not have used UF5408 diodes?
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        #43
        Can you see if its the backlight that's doing the flashing--or the actual image on the screen?
        TELEFIX
        • oddbodd
          • Mar 2013
          • 121
          What's the easiest way of checking the backlight?
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            #45
            Without the back on the set, you can often see through cracks/gaps on the metal-work or screw-holes the backlight working.
            TELEFIX
            • oddbodd
              • Mar 2013
              • 121
              OK, but what what am I looking for?
              I have a picture on the screen, but it flashes/flickers rapidly.
              • Alastair E
                Chief Womble
                • Mar 2013
                • 1963
                • U.K.
                #47
                Well--Is it caused by the backlight flickering....?
                TELEFIX
                • oddbodd
                  • Mar 2013
                  • 121
                  Without checking, I would say yes, probably, but it'll have to wait for now...
                  • wil71
                    • Oct 2014
                    • 17
                    • wales
                    #49
                    Got the diodes today and installed them. Tv is alive again, just want to say thanks for the valuable info on this thread. Ordered Halnziye HY910 heatsink adheseve non conductive from ebay, only £2.30 with free delivery, link below. anyone used this? any good?
                    http://www.ebay.co.uk/itm/2616056625...%3AMEBIDX%3AIT
                      I use that stuff, works great.
                      • oddbodd
                        • Mar 2013
                        • 121
                        There's a small hole in each of the very top corners. I can see a light flashing, so presumably that's the backlight?
                          Yes. That pulsates with the picture right?
                          • oddbodd
                            • Mar 2013
                            • 121
                            Yes. When the picture does stabilise, so does the light in the corner.
                            • oddbodd
                              • Mar 2013
                              • 121
                              Does this mean that the voltage is fluctuating? Should I look at those diodes again?
                                I would check if the outputs from the power supply are stable.
                                • oddbodd
                                  • Mar 2013
                                  • 121
                                  Well, there's a small fluctuation of about 0.5v on some of the pins.
                                    0.5V can be significant, on which rail do you measure this?
                                    • oddbodd
                                      • Mar 2013
                                      • 121
                                      Measurements taken from the connection pins on the inverter board [17CON08-2 - V1] ...
                                      Whilst flickering...
                                      1: 0.00 to 0.01
                                      2: 0.00 to 0.01
                                      3: 1.56 to 1.57
                                      4: 2.75 to 2.78
                                      5: 26.0 to 26.3
                                      6: 26.0 to 26.3
                                      Stable picture...
                                      1: 0.00 to 0.01
                                      2: 0.00 to 0.01
                                      3: 0.23
                                      4: 2.75 to 2.78
                                      5: 25.5 to 25.7
                                      6: 25.5 to 25.7
                                      • oddbodd
                                        • Mar 2013
                                        • 121
                                        Any clues as to the differences?
                                          # 3 does not look right, 1.56V when flickering, and 0.23V when stable.
                                          Do you know if # 3 is the dimming control line and #4 is the BL_ON line?
