LG 47LV5400 No Image
  • rikrikrik13
    • May 2013
    • 44
    I got this LG Tvs not working properly.
    I did many test. When everything is hooked up, I got no image, only some lines on the right side of the tv.
    If I disconnect the right side of the T-CON board, I get half screen working perfectly. With both side connected, only lines on the right side and no image at all (sound ,backlight and everything is working).
    I replaced the T-Con with 2 different one, same problem, I replaced the Main board, same problem. Only thing left is the Power supply (seems ok), panel or??
    Please help!!! Thank you
    Re: LG 47LV5400 No Image
    Bad panel:
    https://www.badcaps.net/forum/showth...ight=LG+47LH55
      You may be lucky and it is just a shorted SMD cap on one side but I am willing to bet that there is a fault with one of the tab drivers.
      • rikrikrik13
        • May 2013
        • 44
        Can you explain me a little bit more how can I test a SMD cap?
        • cashkennedy
          • Aug 2011
          • 668
          Along the side of the screen are thin boards where the 2 ribbon cables from the tcon connect (often you have to disassemble a lot to get to these boards). There are not many parts on these boards, many tab bonds, and a driver (IC chip) every few inches. The SMD caps are small beige cubes, you can test them with the ohm (resistance setting) by connecting your leads to each side, and the resistance should increase very quickly from 0 to out of range oL or something like that. You can also test them with the capacitance setting on your multimeter if you have that setting.
          Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
          • rikrikrik13
            • May 2013
            • 44
            thank you Ill try that!
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • NSkyLab
              Sony XBR-65X900F black and white image on one side (fading saturation)
              by NSkyLab
              I though I've seen all possible kinds of failures but this one is new...
              Colors saturation is gradual.y fading out on the left side of the screen (all colors are fading out). While B&W image is looking good.
              I tried replacing TCon but nothing changed. So this is looking like the panel failure. Is there a chance it can be fixed?
              Any useful measured can be done on the panel's narrow pcbs? Is there may be something similar to taping trick to fix this issue?...
              10-05-2025, 07:37 PM
            • x_orange90_x
              TCL 50S535 bad tcon or panel issue?
              by x_orange90_x
              Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
              03-29-2025, 11:02 PM
            • shlomim412
              samsung ua55es6800 - no image
              by shlomim412
              hi
              having problem with samsung ua55es6800
              tv had backlight on, sound working - responds to the remote control but no image.
              check tcon board - had 12v in but no other voltages present.
              when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
              when leaving only left side connected - again no voltages and no image.
              put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
              kept trying to block less pins on the left ribbon cable...
              05-15-2024, 05:00 AM
              HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
              This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
              09-12-2024, 02:20 PM
