Hello
  • martyparish
    • Dec 2012
    • 313
    Re: Hello
    If it is a bad buffer, it's going to be the one that lines up directly underneath the blacked out area on the screen.
    • JonathanAnon
      • Jul 2012
      • 457
      • Ireland
      Re: Hello
      I've just checked.. What you say is absolutely right, nutty, if from the front the left side is dodgy, then you need to check the right buffer at the back.. I just checked Damon Morrow's book, and it seems that he has made the same mistake..
      but like Marty said, the buffer that is under the part of the screen that is black, is the one that you need to check..
      ^ That was annoying me, so I edited it to reflect the proper naming convention for the X buffer boards.
      • nutty123
        • May 2013
        • 23
        • US
        Re: Hello
        The reason I ask is that I saw this pic and I would assume that it would be the right buffer board that would casue the left side of the screen to go out like it is.
        • nutty123
          • May 2013
          • 23
          • US
          Re: Hello
          sorry it wont let me post the pic but here is the link http://www.plasmafix.com/plasma.php It refers to the the boards as the left center and right as looking at the TV from the back not the front.
          • nutty123
            • May 2013
            • 23
            • US
            Re: Hello
            Jon,
            I see your edit, I thought I was going crazy for a sec. but then I saw your note under edit.
            • JonathanAnon
              • Jul 2012
              • 457
              • Ireland
              #26
              Re: Hello
              Yeah, it's just the sort of thing you have to be very careful with when ordering.. My dad used to work with cars and used to have the same issue when somebody would order a headlight.... Some people would refer to the "left headlight" as the one on the left as you are looking at the car from the front, as opposed to the one on the left as you are sitting in the car...
              Can you remove the board and test it?
              • nutty123
                • May 2013
                • 23
                • US
                #27
                Re: Hello
                I was just about to type nevermind I looked at your pictures wrong. lol
                • nutty123
                  • May 2013
                  • 23
                  • US
                  #28
                  Re: Hello
                  My dad is also works on cars and I did body work for a # of years. hence my questions. lol. I actully had to order a part once for my mom and i finally had to say ok if your sitting in the car what side is it on.
                  • nutty123
                    • May 2013
                    • 23
                    • US
                    #29
                    Re: Hello
                    as far as taking it out and testing I wouldnt be able to do the testing part I dont have a voltage generator. however the part is about $15 bucks so it might not hurt to order one.
                    • JonathanAnon
                      • Jul 2012
                      • 457
                      • Ireland
                      #30
                      Re: Hello
                      Well you're gonna have to take it out anyway, so why not take a couple of high res images of it .... Sometimes the ICs show visual signs of being burned... And if you had a multimeter you could check it for shorts... What you are looking for at this stage is some sort of substantiation of the initial suspicion that this X buffer is faulty..
                        Re: Hello
                        The X-buffer boards themselves rarely fail, it's not impossible but rare. By far the most common fault is the connectors attaching to the boards, they tend to work themselves loose.
                        • nutty123
                          • May 2013
                          • 23
                          • US
                          #32
                          Re: Hello
                          Tom, I will check the connection maybe that is why I got that blue fuzz appear for a sec while moving the TV.
                            Re: Hello
                            Yes, that's a good idea, however, make SURE the power is OFF and the set is unplugged before you fiddle, as you can otherwise cause damage to the plasma panel which is not repairable.
                            • nutty123
                              • May 2013
                              • 23
                              • US
                              #34
                              Re: Hello
                              will do, no more playing with the key parts with the power on... Check
                              • nutty123
                                • May 2013
                                • 23
                                • US
                                #35
                                Re: Hello
                                Well are you guys ready.... Drum roll please.... It was a loose connection from the xr buffer board. the coonection on the main control board to the buffer board was loose the flap of the connector that hold the ribbion down had came up. pushed it down and here is a pic of my working TV.
                                • nutty123
                                  • May 2013
                                  • 23
                                  • US
                                  #36
                                  Re: Hello
                                  • nutty123
                                    • May 2013
                                    • 23
                                    • US
                                    #37
                                    Re: Hello
                                    You guys were a great help!!!!!!!!!!!! Thank you all very much for your advice and helpful tips. I was just going to order it when I said for a goof let me do what Tom said. You all were spot on. !
                                      Re: Hello
                                      Nice one. I sort of expected this, though .
                                      Very strange, almost like the left half of the screen is not properly connected. Can we get a picture of the chassis layout?
                                        Re: Hello
                                        Tom is the king of Plasma repair.
                                        • johnboy1313
                                          • Nov 2012
                                          • 1959
                                          Re: Hello
                                          The guy is a walking encyclopedia of plasma TV knowledge.
                                            HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                            This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-12-2024, 02:20 PM
                                            HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                            09-06-2024, 10:56 AM
                                            HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook 1000 Specification for Upgrade or Repair
                                            This specification for the HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load, Asset Tag & Testntag boardview and 1050 G1 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                            HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                            HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
