Vizio E370VL Display Issue
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Picked this one up for only $20 so I figured it was worth a shot. I haven't had a very good track record so far with any of the Vizio's though. Ok, here's what's going on.
    The very right side of the screen looks almost normal. As you progress left, the screen gets darker and darker and the very left side is almost invisible. Now, at first I thought this to be the backlighting but it appears that everything is lit up looking at the back with the cover removed.
    Also, on top of the dim lighting on that side, it appears that the screen is very slow to respond when the picture changes. It leaves a ghosting of the last image that appears similar to screen burn as well as trails on the screen when objects move. If you leave a still image on it for about 30 seconds it appears basically normal other than the brightness.
    The first pic shows how the previous screen can be seen underneath the current one and in the 3rd you can see the blurring effect as I switch.
    Any opinions are greatly appreciated.
    Thanks,
    Aaron
    Re: Vizio E370VL Display Issue
    Can you try with a fixed colour test pattern? Or ordinary TV? It's hard to see what you mean.
    This is likely a tab bond issue, I have encountered them on some 37" LG.Philips LCD panels, common issue.
    • aaronwt6
      • Apr 2013
      • 855
      • US
      I can when I get home from work this evening but basically what you get with no input device connected is a solid blue screen. The blue looks ok but the no signal message is blurry and slow to react as it moves around the screen. I can do a video of it maybe.
      Also, when the screen first comes on the blue shows up on the right side first then slowing moves across the screen toward the left taking about 10 seconds before the whole screen is lit up.
        Definitely sounds like tab bonds, not bad for $20, there's a risk in damaging the panel when doing the repair, so you have to be careful.
        Budm had success with doing it on two 52 inch panels.
        • aaronwt6
          • Apr 2013
          • 855
          • US
          Ok. I'll get the frame off of it and try putting some pressure on them and see if anything changes. However, I'll post a few additional pictures first this evening.
          Thanks again!
          • aaronwt6
            • Apr 2013
            • 855
            • US
            OK. Here's a few more pics. One of the no signal screen that looks about normal other than the fact that the previous image shows up slightly. The moving ones you can see how the right side looks relatively normal and the left is very blurry with slow response to changes. The last one, I hit pause and you can see again that once the picture sits for 10 seconds or so, it looks pretty normal all the way aorund again.
            • aaronwt6
              • Apr 2013
              • 855
              • US
              Oh, and its clearly an LG panel inside. T-con and display both say LG on them.
                The problem is common with 37" LG displays for some reason.
                • aaronwt6
                  • Apr 2013
                  • 855
                  • US
                  Ok. Looks like quite a pain to get to the tabs on top. I reseated both ribbons going from the T-con to the top and no change. May be a few days before I have time to dig in any deeper but I'll get to it soon.
                  Oh, and get this. Apparently I wasn't the first one to take a look in this thing. I found a Phillips screwdriver wedged behind the cover of the main board. Amazingly I don't thing it ever touched anything important.
                  Thanks as always for the advice,
                  Aaron
                  • aaronwt6
                    • Apr 2013
                    • 855
                    • US
                    You're the man, Tom. I got it going. Bad bond on the left most tab. I put some adhesive tape over it then wedged a piece of plastic between it and the metal bezel to keep pressure on it. Who knows if it'll last but at least I know all the other parts are good.
                    Thanks as always!!
                    Aaron
                      Glad to hear. I prefer to use thermal material because it removes the heat, which causes the fault in the first place.
                      • aaronwt6
                        • Apr 2013
                        • 855
                        • US
                        I need to get some of that for the next time. Any recommendations on where to order it?
                        Couple pictures attached after the repair. I should have taken a couple with it apart but oh well.
                        • wizard13
                          Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                          by wizard13
                          I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                          I have checked the forum and the available documentation but could not find a solution specific to my issue.
                          • Brand & Model: Dynabook Satellite Pro C50D-B-100
                          • Part Number (P/N): PYU13E-00C00PFR
                          • Serial Number (S/N): 22028896H
                          • System Configuration (SC): A1PYU13E1127
                          • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                          • Power Input: DC 19V –
                          02-28-2025, 02:43 AM
                        • Ryan.man
                          by Ryan.man
                          02-04-2025, 12:23 PM
                        • cloudy
                          HELP - Contrast/brightness issue with subtitles on screen
                          by cloudy
                          Hi everybody
                          Since day one I'm having an unpleasant contrast/brightness issue on my Asus laptop.
                          Basically while watching movies, if subtitles appear on screen, the contrast or the brightness of the entire screen increases a lot (not sure if it'is brightness or contrast), disturbing the viewing of the movie.
                          Last year I replaced my screen because got damaged and this contrast/brigthness issue persists. It happens only on the laptop screen, in fact If i plug an external HDMI screen the issue does not occour on it.
                          It occours both on ubuntu and windows...
                          01-01-2023, 05:12 PM
                        • ScHAmPi
                          Samsung UE48JU7000 screen issue after backlight replacement
                          by ScHAmPi
                          Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
                          I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
                          07-15-2024, 05:41 AM
                        • spice_disc
                          Vizio TV M50-C1 reboot cycle and static on screen
                          by spice_disc
                          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                          09-08-2024, 02:37 PM
