Westing house SK-32H570D SK-32H540S screen turns off
  • Beowulf
    • Dec 2012
    • 175
    Sorry but this will be a long post.
    PART 1
    Let me point out that these are two sets with different models but both using the same suspect board (DELTA EADP-130BF A), the inverter/power supply board. Also for completeness let me specify that a different board (Darfon, forgot the version) is sometimes used in both of these models, which usually blows the transformers. This is not the case with these Delta boards.
    Both sets show almost identical behavior, except that one of them does rather intermittently while the other does it all the time. The behavior is that the TVs turn on, display the logo, then screen turns off for two seconds (normal in this design), then screens turn back on and turn off permanently after 2-3 seconds.
    Here is what I've learned.
    IT'S NOT THE LAMPS, AND IT'S NOT THE TRANSFORMERS.
    The problem is located in the section controlled by the transformer that has the smaller heat sink. It's not the transformer being defective cause not only have I removed it and test it, I've also exchanged with one from the other board, not part of this suspicious area, and the problem continues to happen.
    It's not problems with the lamps either, long story, but I've completely ruled it out.
    I've checked the four ceramic **10J capacitors in that section and they're within specs.
    I've also checked C261, **105j and it's also within specs.
    What I have not done is mess too much with the tiny components on the bottom of the board in that section until I get some pointers from here.
    I've also re-touched the solder on all around the transformers and the components around them.
    Now, one important thing. In this board each transformer controls four lamps, through two lamps connectors. If I take a 47k 5w resistor and solder it to the lamps connector, with or without the lamps connected too, the set gets past the two seconds to black problem and works fine. This happens whether I solder the resistor on either of the two lamps connectors. This is how I found out that the problem is somewhat related to this location.
  • Beowulf
    • Dec 2012
    • 175
    Re: Westing house SK-32H570D SK-32H540S screen turns off
    Part 2
    Here is some information about the readings I've got from the inverter IC (OZ9925GN), for which apparently there is no datasheet available.
    These are the pin readings for when the TV is shutting down.
    Pin
    1- 5V when lamps on.
    2-12v when lamps on, 13.7 when lamps off.
    3-5.9v when lamps are on.
    4-
    5-5.9v when lamps are on.
    6-
    7-yes getting triangle wave form.
    8-getting a wave form of some kind.
    9-1.5v then off then permanently on.
    10-1.6v during lamps on only.
    11-1.59v then 1.58v permanently
    12-about 0.042 (goes to 0.090 initially) volts, varies.
    13-4.9 during lamps on.
    14-1.1 during lamps on.
    15-4.2 then off then 4.2 permanently.
    16-2.8 then off then 2.8 permanently.
    These are the pin readings for when the TV is not shutting down (after soldering the 7k resistor).
    1-5V
    2-13v
    3-5.5v
    4-
    5-5.5v
    6-
    8- getting a wave form of some kind.
    9-1.5v
    10-1.4v
    11-1.5v
    12-0.38v when lamps on
    13-1.87v when lamps on
    14-1.5v when lamps on
    15-4.2v
    16-2.7v
    I'll attach a schematic I found from another board using the same inverter IC.
    Plus a document I found that tries to explain what each pin does with some details.
    Regards,
    • Stephen
      MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
      by Stephen
      MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
      03-15-2024, 09:37 AM
    • www
      LG L192WS-BN backlight turns off after 1 second
      by www
      I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
      I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
      03-24-2024, 05:26 PM
    • zklgfs
      Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
      by zklgfs
      I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
      08-11-2025, 02:14 PM
    • andrhouseolly
      Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
      by andrhouseolly
      Hi.
      I kindly ask you to help me solve the problem.
      Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
      The board turns on, there is no image.
      Read more. When the power supply is connected, the front panel indicators light up briefly.
      When you press the power button, the button indicator lights up. The board works
      there is no image, there is no matrix initialization, there is no image on HDMI.
      When turned on, the fans do not spin, but when they warm up they start spinning.
      When you turn off the button, the fans spin up to full speed for a short...
      05-11-2024, 03:14 PM
    • mostachio
      Looking for help diagnosing a 65" Panasonic Viera TV - TH-65DX700Z (Turns on - Clicks - Turns off)
      by mostachio
      Hi Badcaps,
      I've had a friend discard a TH-65DX700Z Pansonic Viera Television and I've decided to have a go at repairing it. If possible could I please get some advice in terms of diagnosing the problem so I can purchase the appropriate parts for repair whether it be components, a repair kit or a replacement board. I am happy to post pictures if required.
      TV Details:
      Model # - TH-65DX700Z
      Symptoms:
      The television turns on and displays a picture then makes a clicking sound and turns off.
      I haven't opened it up yet but...
      09-04-2024, 02:32 AM
