Help needed with MT230DW01 V.0 InnoLux LCD Screen
  • craigc15
    • Jun 2012
    • 53
    In the process of replacing a switcher chip on the display driver board for this screen, I inadvertently lost an adjacent capacitor.
    If anyone can tell me what the capacitance of C230 is, I would be eternally grateful, to say the least!
    If anyone has a cracked MT230DW01 V.0 InnoLux LCD Screen and they would be willing to remove the driver board and send/sell it to me, that works, too!
    Thanks!
    Craig
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • Kiberge
    Samsung LH82QENELGC/EN Help needed - Static line on screen
    by Kiberge
    HI guys!
    I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
    I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
    the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
    This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
    04-22-2024, 11:28 AM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
  • AJ847.63e
    A2338 Screen replacement - Clarification needed. What do you actually loose when replacing the screen with OEM Pulls?
    by AJ847.63e
    Hi All,
    Just wanted to get some clarification on replacing screens on M series machines (M1,M2,M3,M1pro,M2pro,M3pro) as there is so much conflicting information out there. Some say even when using OEM pulls you lose True Tone and only that, others say you lose that and webcam, others say you lose those two and also the lid sensor will not work, others say you lose nothing as long as you use OEM pulls.
    So, which one is it actually? Using original OEM pulls. That seems to be what has caused the confusion, people using cheap aftermarket than being surprised when it does not work...
    03-06-2024, 06:44 PM
