element eldft551 not turning on
  • cashkennedy
    • Aug 2011
    • 668
    Re: element eldft551 not turning on
    I should get this digital scope
    http://www.amazon.com/AGPtek-DSO-Nan...l+oscilloscope
    then yall will really hate me unfortunately I wouldn't know enough about using a scope to work through the lack of documentation on that one
    Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
      That scope is basically useless, waste of money. Don't bother.
      Something like this is worthwhile investment.
      http://www.amazon.com/Rigol-DS1052E-...ywords=ds1052e
      I have the 100MHz version but there's no difference if you just repair TVs.
      Of course a good, old HP, Tek, LeCroy will also suit you well, and can be had for less than the Rigol. I owned an HP 54501A for a time, and it worked quite well, only main complaint, it was very sluggish to use due to the 16MHz processor.
        By the way, I look at the diagram again, it looks like soem one has reverse engineered the board and draw the diagram, there is no company name, SCH revision, etc. but it seems to be close enough for troubleshooting.
          I don't know in particular where the schematics came from, I just got a disk of them . Some are clearly engineering diagrams, others not so sure.
            So @CHKDY, where are you at this point?
            • cashkennedy
              • Aug 2011
              • 668
              Power supply appears to work fine now.
              Tcon lvds connector and lvds cable burnt beyond repairability.
              Ordered tcon + lvds package on ebay for 33 after shipping.
              100 dollars for broken set + 33 for parts. Hopefully = ~300 in profit.
              Bought a 42" that has inverters or bulb problems (seller said his house had a power surge and insurance covered all his items)
              Buying a 50" samsung plasma that was part of the badcaps class action lawsuit. wont start up. paying $125... i think im paying to much, but im not tight on cash so ill figure out if im loosing money (not making enough to make my time worth it) once i run into 1 that i cant fix.
              • cashkennedy
                • Aug 2011
                • 668
                I am still slight worried that it seems unlikely for saran wrap to have shorted the lvds, since it would have been just barely in contact with it, saran wrap does have static cling though ... (saran wrap is a brand name, it england they probably call it like nicker waxing or something retarded, or misspronounce cellophane as chellofan)
                If you have any sugestions for how to test the lvds output of the mainboard for "safety" please tell me.
                I did some basic voltage readings on all the conectors and the 12v wires were 12, and the lvds wires all ranged between .5-2v. Im not sure if current could be an issue on these, since the wires are tiny.
                  Uh, we call it cling film here. Let me remind you Sir, that we invented English, you just modified it into the bastard child* known as American English.
                  *not that I don't appreciate some parts of American English. Like color makes much more sense than colour. And the storage compartment of a car does look more like a trunk, than a boot. And, indeed, you are more likely to know a sidewalk from a pavement. But your misuse (ney, abuse) of "hold down the fort" takes the biscuit.
                    I hope that the switched MOSFET that supplies the B+ to the T-CON board did not get damaged when the cables burnt up, you will have to trace out the B+ trace at the connector to the T-CON back to the switched MOSFET. The MOSFET is turn on when the TV is turn on, so the cuurent will flow through the MOSFET to the T-CON fuse.
                    • cashkennedy
                      • Aug 2011
                      • 668
                      I have never heard of the term B+, what does that refer to? Is the 12v that is provided to the board provided by B+?
                      Other then the blue / white twisted pairs there are 3 red wires on the main board side. These carry 12v power. There is also a few black wires scattered through out that appear to be grounds. The red wires line up to the fuse which still tests good on the tcon.
                      The ground wires are really at the heart of what burnt on the connector from what I can tell?
                      There are also 4 control wires that turn tcon on / affect contrast I suppose those are all no where near where the lvds burnt up. The whole wiring harness has a large screwed case ground on 1 end, but I assume that's just connected on 1 end as a shield, and does not actualy connect to the tcon through the conector?
                      • cashkennedy
                        • Aug 2011
                        • 668
                        I replaced the tcon and lvds cable and set works fine now.
                        Whether the connector fried from the cellophane or because I didn't have the tcon properly grounded we will never know.
                        So to recap > power supply turns off voltages after 2 seconds can be possibly fixed by removing failed transistor in the error sensing circuits, and make sure you don't put cellophane near circuits , and don't test tcons without them being grounded well?
                        • flysky
                          Gigabyte H610M S2H V2 help to identify the element.
                          by flysky
                          There is a motherboard Gigabyte H610M S2H V2 (DDR5), I can't find boardview
                          Help to identify the element, marking on the element - C31PH. It stands next to the USB 3.0 and it looks like it is ESD Protect chip. We need a datasheet to this element. Maybe someone has already identified such an element. Help please.​
                          01-23-2025, 07:21 PM
                        • прямо
                          Viper22A 5VSB circuit
                          by прямо
                          So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                          In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                          01-13-2024, 07:05 PM
                        • kotel studios
                          FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
                          by kotel studios
                          Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
                          Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
                          I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
                          Any ideas where to go next?
                          02-23-2025, 11:47 AM
                        • EasyGoing1
                          The best way to drive a heating element?
                          by EasyGoing1
                          I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
                          What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
                          This is the general setup that I have now.
                          This is what the...
                          01-25-2023, 11:29 AM
                          Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                          by sam_sam_sam
                          I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                          I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                          12-16-2023, 08:39 PM
