element eldft551 not turning on
  • cashkennedy
    • Aug 2011
    • 668
    Re: element eldft551 not turning on
    No, unfortunately at home I have my 7 function clamp on multimeter ($12)
    in my condo I have the 7 function cheapo 5 dollar one
    maybe I should splurge and get the 11 function one ($20) but the reviews say that one has a horrible screen that fails... I need another multimeter for home though cause I keep leaving mine at work / and my neighbors always borrowing mine...
    these are all from
    http://www.harborfreight.com/catalog...t?q=multimeter
    Ill attach new pictures in a minute.
    Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
    • cashkennedy
      • Aug 2011
      • 668
      Took forever to figure out a way to get no glare. Finally propped the board up vertically in a extremely bright room. Hopefully you can make do with 4 pics, if you really need 10 pics like you showed I can go take some more *sigh*...
      BTW clamp on part of the multimeter is worthless. I didn't buy it for electronics obviously, but for AC repair and what not , but the clamp only measures current and not voltage ...
        Well, of course the clamp only measures current. The definition of a voltage is a potential difference between two points, how would you design something with a single clamp to do that?
        AC current is still useful though I prefer clamp with both AC and DC.
        • cashkennedy
          • Aug 2011
          • 668
          Yep, you described the downside better then me, it also is a really finicky clap, not only do you need the wires 90 degrees from the clip (which is understandable) but you also have to try a lot of different positions inside the clamp / like move it around and you get all kinds of varying readings ...
          Theres a $44 multimeter also at harbor freight, that one looks like a winner all around, its basically a knock off fluke 87 with auto ranging and everything. I think I qualify as using mine enough to warrant the price, Im practically using mine on 3 projects a day... all my stuff has been dieing on me... had 2 computers in a row go bad on me for caps in the power supply / had replacement all on hand though
          • cashkennedy
            • Aug 2011
            • 668
            Any luck? or knowledge gleaned from the more detailed pics?
            If your still having trouble making parts out I can take 10 smaller shots with a digital camera instead of that phone.
            Board is laid out horribly... cant see a p/n on a single damn one of the FET's and other to-220 parts.
            • cashkennedy
              • Aug 2011
              • 668
              From what I can discern from the secondary the large transformer creates 12v only then there are 3 identical power diodes (correct term?) mounted to the heatsink: 2 power diodes for the 24v section , 1 for the 12v .
              The smaller transformer leads to a power diode that creates 1 voltage follower by a dc regular (d452a) that makes it the 5v .
                I have not have a chance to look at the new pictures yet.
                  Forgot to link to the MLT199 schematic. Got the CD yesterday and have already got about 1,100 schematics up. Still, I haven't hit the 10GB threshold, yet!
                  http://www.tgohome.com/ServiceManual...&Search=Submit
                    That is great to be able to get the diagram, thanks TOM.
                    OK, on page 3 top left corner of the page, there are VCC1 (for PFC IC, which is working), and the VCC2 for the 12V/24V SMPS IC UA4 pin 12 on page 2, check and see if you have 12V or more on VCC2.
                      I hope it's the right one. Shame that there are no component values on it.
                      • cashkennedy
                        • Aug 2011
                        • 668
                        Thank you Tom! Schematic isn't perfect (a few components are marked differently / probably a few versions of this power supply / with different spatial requirements / so numbered a few components differently) but its definitely close enough to count on.
                        I think weve isolated the problem down a lot > the vcc2 reads 11.5 - 12 ish VAC against cause ground when the set is just plugged in , but when you turn the set on (LED lit blue) then it drops down to 9 VAC. I assume it should stay steady at 12 if things were working as designed? There is no "lag" time between pressing the power button and it decreasing by the way, the millisecond I press the power button it drops down to 9 vac.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #32
                          Wow, your HF multimeters need replacing if they are reporting VAC when they should be measuring DC voltage on the secondary side of the PS.
                          --- begin sig file ---
                          --- end sig file ---
                          • cashkennedy
                            • Aug 2011
                            • 668
                            The measurements he requested are on the primary side, and I can test VAC or VDC if I want with my multimeter...(hopefully that's just sarcasm about my meter) but if they wanted VDC I can retest for that, Its really late at night / I just worked 12 hours and yeah now that I think about it VAC doesn't make a lot of sense as these chips are after the bridge rectifier, I was assuming primary = AC , secondary = DC when I took the measurement , but that's not a good rule at all lol.
                            > tv off : vcc2 = 9.1 VDC
                            > tv on : vcc2 = 6.75 VDC (first second or two of "on" was around 6.35 VDC, then stabilized at 6.75)
                            At least I specified VAC vs VDC so there was no ambiguity
                            I am buying the $44 dollar multimeter tomorrow (fluke 87 knock off) , clipped the 20% off 1 item coupon from my sunday paper , so should be around $39 after tax. Found a 50" plasma and 42" LCD and a 50" lcd(Samsung in the bad cap class action suit) all in my area so might be fixing a bunch more big ticket TV's...
                            • cashkennedy
                              • Aug 2011
                              • 668
                              That IC that were testing the VCC on is an sg3525an not sure what brand / but the STM and motorolla sheets I looked at were very similar
                              Supposed to have 8-40 VDC powering it, so looks like we drop out of range once the set is on.
                              If im interpreting the power supply schematic right they get 12v power(or whatever voltage vcc should be) from the smaller transformer? But I cant figure out how 12v(or whatever) comes out from the same side as the 400v goes in... does the transformer convert 400v on the primary to 24v on the secondary side , then convert that 24v on the secondary to 12v on the primary, or is it better to think of it more as 400v going through the transformer once, and you can layer as many outputs as you want off that, and have those output voltages leave on either side / wherever you have room to stick pins?
                                "I think weve isolated the problem down a lot > the vcc2 reads 11.5 - 12 ish VAC against cause ground when the set is just plugged in , but when you turn the set on (LED lit blue) then it drops down to 9 VAC." You are working in the primary side, case ground cannot be used for ground ref point, the negative leg of the main DC filter cap in the primary side is the ground ref point of the primary circuits you are working on. The only time ou use the chassis as the ground ref point is when you are working on the secondary side (cold side).
                                The meter should be set to DC for checking the VCC2 DC Voltage.
                                • cashkennedy
                                  • Aug 2011
                                  • 668
                                  I retook the measurements using the negative leg of the main cap
                                  vcc when off > 0
                                  vcc when "on" > 15.1 V (I tested that in a few places along the path to the IC, as well as directly on the actual vcc pin of the IC
                                    That VCC2 is 15.1VDC? or that is VCC1?
                                    • cashkennedy
                                      • Aug 2011
                                      • 668
                                      That's VCC2 as far as the "schematic" labels it. But the datasheet on the part shows pin 13 being VCC and pin 15 being VCC2, but both are connected so are essentially the same thing.
                                      Sorry for the confusion.
                                        OK, so the IC is getting correct DC for it to function, I will have to look at the digram to see what else to check in that circuit.
                                        So far that IC UA4 drive the coupling transformer directly, so it can be bad IC. Can you read the number on that IC?
                                        • cashkennedy
                                          • Aug 2011
                                          • 668
                                          UA4 (the same IC I was testing VCC2 for) is the sg3525an that I linked a datasheet for above.
                                          I did some testing based on the diagram and T4-A has 5vDC on pins 3 and 4 for 1-2 seconds after turning "on" then goes away. Also the FET's QA2 and QA3 read out of range (over 1000 vDC) for 1-2 seconds after turning "on" then goes away. So it appears the problem occurs at UA4 or somewhere upstream of that.
                                          • flysky
                                            Gigabyte H610M S2H V2 help to identify the element.
                                            by flysky
                                            There is a motherboard Gigabyte H610M S2H V2 (DDR5), I can't find boardview
                                            Help to identify the element, marking on the element - C31PH. It stands next to the USB 3.0 and it looks like it is ESD Protect chip. We need a datasheet to this element. Maybe someone has already identified such an element. Help please.​
                                            01-23-2025, 07:21 PM
                                          • прямо
                                            Viper22A 5VSB circuit
                                            by прямо
                                            So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                                            In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                                            01-13-2024, 07:05 PM
                                          • EasyGoing1
                                            The best way to drive a heating element?
                                            by EasyGoing1
                                            I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
                                            What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
                                            This is the general setup that I have now.
                                            This is what the...
                                            01-25-2023, 11:29 AM
                                          • kotel studios
                                            FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
                                            by kotel studios
                                            Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
                                            Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
                                            I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
                                            Any ideas where to go next?
                                            02-23-2025, 11:47 AM
                                            Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                                            by sam_sam_sam
                                            I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                                            I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                                            12-16-2023, 08:39 PM
