Low Voltage sony kv14af1
  • duldog
    • Aug 2006
    • 5
    i've got a sony kv14af1 with low voltage from its power suppy (B+ is 98V, the other outputs are also low) causing it to have a variety of symptoms.
    i separated the power supply from the rest of the tv and substituted a 60w bulb at its main output. the output is still the same.
    i've replaced the power supply ic(strf6614), opto-isolator, ref amp (se135) but the output is still the same.
    i don't have schematic for this unit and i'm running out of ideas. any help would be greatly appreciated. thanks!
  • Rainbow
    • Aug 2005
    • 1374
    Re: Low Voltage sony kv14af1
    Are the caps good?
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      make sure the input caps are ok.
      had a small sony table set that had a dim shrunken pic with hum bars.
      main filter was open.
      had a tag from a tv shop that said bad flyback.
      ROFLOL!
      • duldog
        • Aug 2006
        • 5
        thanks for the replies!
        i've already already replaced the main filter cap in the primary side as well as all the caps in the secondary side.
        i'm already running out of ideas, help me please. thanks!
        • Johnnysan
          • Jan 2007
          Sounds like the PS is operating off-frequency. Replace the electrolytics in the power supply that are 1 to 4.7uf.
          • Fernon@Repair
            Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
            by Fernon@Repair
            i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
            VCCIO voltage ok
            VCCSA Voltage OK
            VCCPLL Voltage OK
            Ram Voltage ok
            RamVTT OK
            VPP 2.5 OK
            But No Core Voltage
            and i want to this vrm ic datasheet or pinout (ISL69269)
            anyone have this ic pinout voltages?...
            06-25-2025, 07:19 AM
          • electron_jj
            Panasonic TH-L42D25A checking the PSU output voltage
            by electron_jj
            Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
            I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
            08-29-2021, 08:13 AM
            Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
            I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
            The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
            Now...
            06-09-2024, 10:57 AM
          • Carlos#2003%
            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
            by Carlos#2003%
            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
            02-15-2024, 07:52 PM
            ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
            3+1 Voltage Regulator for IMVP-7/VR12 CPUs
            Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
            core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
            configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
            serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
            Based on Intersil's Robust Ripple Regulator...
            11-05-2024, 03:24 PM
