Philips 42PFL3603D/F7 blowing fuses
  • jaxmoto
    • Dec 2011
    • 18
    I have done everything I can find in testing this thing, I'm at the limit of what I know how to do.
    Philips 42" LCD
    Bought this TV locally and was told it was knocked out by lightning along with a bunch of other stuff in an old lady's home, so her neighbor was selling off what he could.
    Fuse was blown and it immediately blows replacements.
    The only obvious damage is the resistor above the fuse which fried (second picture). The rings were fried off so I can't tell what it should be. It tests 5.14k, so it isn't open.
    I have tested the bridge rectifier using instructions here and elsewhere, everything checked out.
    I tried just checking resistance across the mosfets and everything seems to match up (from one to the next they match).
    The only thing I found is that about half of the diodes on the board show 0v in both directions, while the other half show OL/.55v.
    The first question would be if all the diodes in circuit should be testing properly, or if I actually have about 5 bad ones (these are all on the hot side).
    Secondly, where should I go from there?
    Thanks, pictures attached.
    Re: Philips 42PFL3603D/F7 blowing fuses
    OK, please take good closed up pictures divide them into 4 or more sections so I can really see all the components, I will need both the top and the bottom sides.
    Is there a chassis number on the model number sticker? It will be something like:
    42PFL3603D/F7 L09.1
    You should also test the components off the board.
      R101A to me looks like it is the Class X safety discharge resistor. It is supposed to fail short circuit on failure (maybe becoming short at higher voltages, like a varistor), so it is failed. It should be of the order of 470k ohm to 2.2Meg ohm. Must have been a really bad failure to damage that, so there's probably more than one fault.
      It would also be good if we could get pics of the bottom of the board.
      • jaxmoto
        • Dec 2011
        • 18
        Ok here are some more pictures. Like I said, all I know is that it supposedly was a lightning strike.
        I wouldn't put so much effort into it, but replacement power boards go for about $100 for this set.
        This is the best my camera can do.
        The chassis number shows LC8.1U LA
          OK, that R101A looks to be a fusible resistor feeding the standby controller, so I figure the standby controller may be bad or one of those diodes in series could be bad too.
          • twbranch
            Mad Nerd
            • Oct 2012
            • 153
            In my experience a diode or transistor blown will cause fuses to blow immediately. Obviously it depends what the diode or transistor is being used for but I will second tom66 on this one.
            • bigpapabooga
              • Apr 2013
              • 5
              was this ever resolved? i have a similar prob
              • running on empty
                • Oct 2013
                • US
                I am looking for the value of R101A. Mine was charred and cannot tell the colors
                • Chris15x
                  • Dec 2013
                  If you are still looking, the resistor is the same as R2, 540 ohms.
                  • sordids999
                    • May 2013
                    • 2161
                    hello
                    does anyone know the dimensions of the stand screws i have seemed to have misplaced them
                    • andrew3968
                      • Oct 2016
                      • 4
                      Where to buy the resistor ? Can't find it anywhere to buy
                      • tvtimmy
                        • Mar 2015
                        • 1160
                        • usa
                        If the set keeps blowing fuses, replace u101.
                        • andrew3968
                          • Oct 2016
                          • 4
                          The fuse isn't blown at all. The resistor R101A is burnt . Have two swollen capacitors. Having a very hard time . Trying to buy the resistor 540 ohms . Only found 560 ohms
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            For testing purposes you could series two resistors to get the value
                            270 + 270 = 540 Ohms
                            • andrew3968
                              • Oct 2016
                              • 4
                              But after testing it . Where would I find a 540 ohm resistor?
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                Try mouser and search for 540 Ohms in search box
                                • andrew3968
                                  • Oct 2016
                                  • 4
                                  Thank you checked it backordered till at least 11/23
                                    How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                    by sam_sam_sam
                                    About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                    Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                    Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                                    12-14-2023, 07:45 PM
                                  • Sik_6ty_Sixx
                                    HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                                    by Sik_6ty_Sixx
                                    So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                                    02-18-2025, 05:06 AM
                                    Surface Mount Fuses Fundamentals Datasheet
                                    TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                    TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                    10-07-2024, 06:07 AM
                                    1970 Metal Lathe Control Circuit blowing fuses on the 120 volt section failing meager test below 60 mega ohms
                                    by sam_sam_sam
                                    I was working on this machine yesterday and I now going to use an incandescent lights instead of a fuses to figure out what the issue is with it blowing control voltage rail but this not the only issue the coolant pump failed the meager test as well as the main motor as well this motor has 12 motor wire leads instead of the normal 9 wires
                                    This metal lathe has a weird motor setup it has a soft start motor with a ā€œYā€ and a delta type of motor winding setup and it is not done in the motor pucker head enclosure it is with four different contactors wired in a configuration I have not...
                                    12-29-2024, 07:18 AM
                                  • mon2
                                    Gemsound PAX-105 Audio Amp blowing fuses
                                    by mon2
                                    Hi. New to this side of the forum.
                                    Have an audio amp (Gemsound PXA-105) that keeps blowing the 3A fuses upon power up. Owner stated that the amp was on when he plugged in the input (mixer board) and that started this chaos.
                                    Would a schematic be available? Advice on what to check? Power supply / output amp transistors? Do see the power on green led turn on for a brief moment before the fuse blows.
                                    Thanks.
                                    10-30-2024, 08:33 AM
