This lcd was given to me and the problem it has is the picture looks psychedelic for the first 8 minutes or so after start up. After that the picture seems to look fine. I read the lcd trouble shooting guide and and seems like it might be a bad tcon board. Any confirmation would be great. What i don't understand is why the picture looks good after the elapsed time. Can anyone explain this? Ill post before and after pictures shortly
toshiba 40rv5257 lcd bad pic at power up
Tags: None
Re: toshiba 40rv5257 lcd bad pic at power up
Likely something is warming up and starts working proper after it has reached a higher temperature.
So, you should take a hairdryer to the boards of the TV (covers off) and try heating up each and seeing if the problem gets better.
My guess would be main board over T-con.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... - Loading...
