futisu p42vha20es-plasma panavision
  • willyam1
    • Feb 2012
    • 112
    • israel
    hi.
    problem is got screen and pic for a few sec and then it 'clicks' and shut down and led is flickering its seems like a protection mode.
    all boards are made by Panasonic .
    seems to me that the problem is in p.s board TNPA2599 AB.
    ANYONE HADE A PROBLEM LIKE THIS?
    Re: futisu p42vha20es-plasma panavision
    Does the LED blink a number of times then pause, repeating this sequence until turned off?
    • willyam1
      • Feb 2012
      • 112
      • israel
      no its shutdown and then its blinking and cant be operet until power is off and on again
        So, can you post some pictures of each board? We can test points like TPSOS6, TPSOS7, TPSOS8 to determine where a fault may be.
        • Jack00
          • Jul 2022
          • england
          I also have this fault in my tv also and the red led blinks. What is the fault?
          • bamboofuto
            Redmibook 15 (67591_1_15) screen flickering problem
            by bamboofuto
            does anyone know how to solve Redmibook 15 (67591_1_15) screen flickering problem.
            i tried changing lcd 2 times but still got the same problem.
            when connected to external display everything normal....
            09-27-2024, 09:44 PM
          • theone111
            by theone111
            3. Problem: TV shuts down
            07-22-2024, 10:36 AM
          • Zeonalbasta
            Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
            by Zeonalbasta
            i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
            The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
            09-13-2024, 01:17 PM
          • reessi
            ACER BM320 Monitor - Horizonal Flickering Lines After a While
            by reessi
            The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
            They are black on the right and gradually fade to nothing on the far left.
            They start either after 5 mins or up to 2 hours after so annoying for testing.
            They flicker continuously very fast! With a slight pause milli-second every second.
            Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
            I tested each half by removing the first the left flex from...
            06-03-2025, 09:58 AM
          • domu
            Viewsonic VS16217 strange problem - white flickering screen on power up
            by domu
            As per subject, on power up display shows no image, but white
            flickering screen. Strangely, it only happen after power was lost
            when it was on. After power returns - white screen only, but if
            disconnect power for 12-24 hrs, and connect then again monitor
            works normally.
            Any clues how to go about it would be greatly appreciated.
            07-18-2023, 04:57 AM
