Sanyo DP52449. Won't turn on & main board problem.
    Re: Sanyo DP52449. Won't turn on & main board problem.
    Can you perhaps ask for a photo of the item?
    Can you supply pictures of connectors on each end, maybe they are considerably different?
    I can see if I can get the SM; if I can, it should have a parts listing so you can find the exact part.
    • johnboy1313
      • Nov 2012
      • 1959
      I can get pictures of the connectors on the boards but not the ends of the cable. I asked for more info and was told that their system is currently down. Seems odd that she could get me a price and a part number if the system was down. It also seems like that happens a lot when I deal with authorized parts dealers and companies.
      A SM would be super cool.
        I hope he comes back to me ASAP.
        • johnboy1313
          • Nov 2012
          • 1959
          Just got off the phone with Sanyo. They won't sell me the part because I'm not a service repair center.
          The picture with the connector labeled K5LVDS is the main board. The picture with the connector partially shielded is the PC board.
            Well... screw 'em. I'll see what the manual brings.
            • johnboy1313
              • Nov 2012
              • 1959
              Check this out. Direct from Sanyo.
                That's nice. How'd you get it?
                • johnboy1313
                  • Nov 2012
                  • 1959
                  I emailed them.
                    Nice.
                    • johnboy1313
                      • Nov 2012
                      • 1959
                      Just sent Coppell TV ~$20 for the cable. I'll update when it arrives.
                      • johnboy1313
                        • Nov 2012
                        • 1959
                        The cable arrived in the mail today. I put it in, fired it up, and ugh...
                        Is this a T-Con issue? The screen is greyed out. I'll connect a source later this afternoon and get a pic then too.
                          Check the brightness control. If not, check the T-con is the same model, and check the gamma IC voltages.
                          • johnboy1313
                            • Nov 2012
                            • 1959
                            Not sure how to do this.
                              Can you take a picture of the T-con?
                              • johnboy1313
                                • Nov 2012
                                • 1959
                                Yeah. I've still gotta get the back off. It may be tomorrow.
                                • johnboy1313
                                  • Nov 2012
                                  • 1959
                                  What a pain in the a$$. It was nearly impossible to get the back off this thing. The wires inside are all too short to pull the back away far enough to get anything unplugged. I was finally able to get the T-Con out. Before I pulled it out, the screen was all washed out. I pulled it took some pics and re-installed it. Now half the screen is pink with vertical lines and half the screen is white with vertical lines. Wiggling the cables from the PC board to the T-Con makes the lines come and go. Reseating the cables eliminated the lines, but not the pink or white. Reseating the ribbons to the panel had no effect. No amount of flexing or tweaking the screen has any kind of effect.
                                  From the test points...
                                  C618-C601
                                  .4
                                  2.62
                                  3.24
                                  3.9
                                  4.3
                                  4.6
                                  4.8
                                  5.0
                                  7.0
                                  7.5
                                  9.4
                                  9.6
                                  9.8
                                  10.1
                                  10.5
                                  11.08
                                  11.68
                                  14.09
                                  C518/VG_A18-C501/VC_A1
                                  .35
                                  2.42
                                  3.11
                                  3.66
                                  4.14
                                  4.56
                                  4.93
                                  6.0
                                  7.26
                                  7.66
                                  8.9
                                  10.1
                                  10.36
                                  10.7
                                  11.2
                                  11.68
                                  12.3
                                  14.09
                                  From what I read, it looks like these all appear to be correct. After buying the TV, the main board, and the LVDS cable, I'm in it for $200. I'm not gonna make a dime off this thing at this rate. I really hope this isn't a bad panel.
                                  • johnboy1313
                                    • Nov 2012
                                    • 1959
                                    Well, I found a used T-Con with both cables for $20 on eBay. Fingers crossed.
                                    • johnboy1313
                                      • Nov 2012
                                      • 1959
                                      I guess I forgot to follow up. I ordered a second T-Con and there was no change. Unfortunately, this one's been sitting in the corner, untouched since June.
                                      • joeshannallie
                                        • Dec 2013
                                        • 103
                                        • usa
                                        #39
                                        Did you ever find the problem with this tv?
                                        • johnboy1313
                                          • Nov 2012
                                          • 1959
                                          No, I threw it away.
                                          • Dani_2024
                                            by Dani_2024
                                            10-28-2024, 05:06 PM
                                          • jb_Bak
                                            by jb_Bak
                                            CN6401
                                            Pin 01 NC
                                            Pin 02 NC
                                            Pin 03 "BL_ON": 0V
                                            Pin 04 "N/C"
                                            Pin 05 "STBY 3.3V": 3.5V
                                            Pin 06 "GND": N/C
                                            Pin 07 "AC_OFF"...
                                            09-27-2021, 04:52 PM
                                          • JDC
                                            (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                            by JDC
                                            ONN 100012588
                                            Issue: No Power, Then Rebooting After Main Board Change
                                            Short answer: replace main board and power board
                                            Technical answer: replace main board and Q306 & Q307 on power board.
                                            Long answer:
                                            TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                            07-15-2022, 07:39 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • cheeky2
                                            by cheeky2
                                            05-25-2024, 03:27 AM
