Philips 42pfl5332 no picture
  • CroTech
    Student
    • Dec 2012
    • 149
    • Croatia
    Hi there, I have a philips 42pfl5332/10 which was at first hard to turn on, it took some time to turn it on (I know that sounds a lil bit dirty ) joke aside, a few days ago it would not turn on at all...
    I knew the problem was with the capacitors on the power board but I was too lazy to replace them before this happened. Finally I have replaced them and now the TV turns on instantly, at least the LEDs but there is only sound and no picture.
    What could be the problem?
    I checked the fuses on the power board and none have been blown, I checked the voltage regulator and it is fine (3,29V on the middle pin)... I also checked the transformer, although I am not sure if that´s the way to check it.
    The pictures will give better description than me blabing...
    Re: Philips 42pfl5332 no picture
    Make sure the pink insulated connectors going to the power supply are well connected and seated properly. Check if the backlight lights correctly by observing the LCD in a dark room.
    • CroTech
      Student
      • Dec 2012
      • 149
      • Croatia
      I rechecked them several times, I thought it has to be the problem but no luck...
      Also I thought of backlight, could it be that the picture is there but there is no brightness, still no luck, there is definently no picture.
        You need to see in a dark room if the screen is lit or not because that is very important in determining where the fault is.
        • CroTech
          Student
          • Dec 2012
          • 149
          • Croatia
          I will do that, but in a few days, since I am at a dorm and my TV is at home...
          Can anyone verify if I checked the transformer secondaries right?
          Picture #3 is transformer´s upper side, and picture #7 is the solder side
          where I measured the impendance.
            That would appear correct; however, the resistance check on single-transformer inverters is generally unimportant, apart from the windings not being open (high resistance.)
            • CroTech
              Student
              • Dec 2012
              • 149
              • Croatia
              Ok, I have the power board with me and a multimeter...
              Is there anything else I could check?
                Not really until we know what the fault is, no backlight or no video with lit up screen, diagnosis is completely different.
                • CroTech
                  Student
                  • Dec 2012
                  • 149
                  • Croatia
                  I put the power board back on and connected all the cables, turned TV on, it was almost midnight and the sound was on but absolutely no picture, no backlight no picture.
                  Then I took down the logic board, noticed a little bulge on the 470uf 16V SMD capacitor, replaced it with gluxon 470uF 25V put the logic board back on tried turning it ON for several times and nothing, then all of a sudden TV worked just fine.
                  Now, I have the problem that when I turn it off I have to keep pushing power button on remote for like 20-30times and then I get the TV working again.
                  What could cause that problem?
                    During the fault, check BLON. If BLON is missing (<1V), then the fault is with the main board. If BLON is present (>2V) then the fault is with the inverter/PSU.
                    • CroTech
                      Student
                      • Dec 2012
                      • 149
                      • Croatia
                      Since I dont have the boards with me, I presume the BLON is the voltage found on two connectors that connect the logic board and power board together?
                      So u are saying by measuring this voltage while the boards are connected and powered on we can now where to look for the problem?
                        Yes.
                        • vbuble
                          • Apr 2013
                          • croatia
                          Hi Lule
                          I realised you are kind of expert and I will ask you to help me.
                          I have an Philips LCD TV - 42PFL9732D/10 for about four years.
                          I did experience several switch-on problems, no picture - sound ok.
                          After switching off and on again it appear to operate everything in best order.
                          Few days ago I did not receive any picture at all after many switch on & off.
                          At the same time sound, remote control and ambilight are fully operational.
                          Asking your advice.
                          Vinko - Trogir
                          • CroTech
                            Student
                            • Dec 2012
                            • 149
                            • Croatia
                            Hi Vinko,
                            The same thing happens with my TV. Sometimes it takes 30-50 power on and offs to get it working. So I assume we have the same problem. Once I realize and locate the problem I will post the solution here.
                            Jel sunčano u Trogiru? Oće bit šta za prvi maj
                            • Schwoin
                              Philips 243v5lhsb00 Monitor Picture too bright
                              by Schwoin
                              Hey everyone,
                              the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
                              While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
                              you can see them on the top half of the photo.
                              At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
                              03-21-2023, 12:40 PM
                            • madyoyo
                              Philips 37pfl560: Yellow picture
                              by madyoyo
                              HI.
                              I have a weird problem with an old Philips 37pfl560 TV i put out of storage: the picture have a noticeable yellow hue, and its not caused by the settings (did a factory reset). I've never seen this before. I will try to get a photo with a real camera, with my phone its hard to see because of automatic white balance, but in real live the whites are really yellow.
                              Anyone have an idea of what can cause this? Can CCFL tubes get "warmer" with time? This tv have several analog inputs,so its nice for retrogaming....
                              05-30-2025, 10:16 AM
                            • charlesdutcher
                              No picture issue in Philips Chassis FTL2.1
                              by charlesdutcher
                              My Plasma Philips 37inch chassis FTL2.1 does not show picture. It automatically goes into protection mode after 30 seconds (red led blinks at 3Hz)
                              Is there someone having any symptom like this? How to fix it?
                              Thanks in advance!​
                              08-06-2024, 09:55 PM
                            • markolino
                              Philips 58PUS7505/12 Backlight OK / no picture.. Help
                              by markolino
                              overnight my philips is 2 years old but unfortunately it is no longer under warranty.. started joking..
                              the picture became black.. but the next day when I turned it on, I still saw a little something... But now it's just black..
                              the backlight works normally.. the sound too.. the motherboard also shows that it is ok..
                              I suspect a T-Con panel. Do you think the panel is shorted?
                              below I am sending you a video about my TV and how it behaves.
                              I also tried disconnecting the ribbon cables. first the left one, then the right one.. but I can't find out if the panel has...
                              09-20-2023, 05:07 PM
                            • betmen
                              TV Philips 43PUS8505/12 - horizontal line and picture jumping
                              by betmen
                              TV is Philips 43PUS8505/12, bought in 12/2020, so the two-year warranty has expired about 5 mounth ago...
                              Problem is that 15 minutes after TV is turned on, the horizontal lines appear and picture start jumping up and down.
                              I suspect that T-CON is faulty when wormed up...
                              I separated all the cables from the T-CON and cleaned them but there is no change.
                              Eco mode is disabled, software is up to date, I make factory reset and reinstal TV from TV menu...no change, problem is stil here.
                              Anibody have some thoughts?...
                              05-30-2023, 10:19 AM
