LG 42PM1M Screen burn in, possible to fix?
  • DakotaKid
    • Nov 2010
    • 165
    This is an LG plasma 720p (768) monitor, no TV tuner built in. I was given this TV by a friend who owned a fitness center. The TV was used to display info about upcoming events but unfortunately they had their logo and a few display elements onscreen full time, no screen saver, no rotation of the elements to different places on the screen. It was essentially a powerpoint running 24x7 for 4 years.
    I can play a movie and it all displays fine except I get some "burn in" where the images were displayed and I get some amount of Tom66's "sparklies" throughout the screen. The first thing I intend to do is check PS and Sus voltages and adjust them into spec using Tom66's great plama guide. The picture isn't unbearable for a TV to put in the garage but it would sure be nice to get it back to a decent operating state for a spare room in the house.
    My question is this...can this ghost image phosphor burn be fixed without replacing the entire panel (which I wouldn't want to do)?
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
  • Chrissygizmo
    by Chrissygizmo
    02-10-2025, 12:33 AM
  • spice_disc
    Vizio TV M50-C1 reboot cycle and static on screen
    by spice_disc
    I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
    The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
    09-08-2024, 02:37 PM
  • ipatch
    ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
    by ipatch
    i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
    08-24-2024, 02:36 PM
