Panasonic TCP50C2
  • cqz123
    • Apr 2013
    Panasonic TCP50C2
    My main tv died about 2 months ago. I ended up just buying a new one to replace it but put the old one off to the side in hopes of fixing it later. I've tried search for similar color problems but can't find anything that quite describes the problem or a solution figured I'd throw it in here to see if anyone has seen this problem before. The colors look all wrong, not sure if its just on e of the rgb colors not working right or what. Any help is appreciated
    The menu should look like a navy blue like below
    Re: Panasonic TCP50C2
    I would access the service menu and try a reset first.
    VOL- held on TV and zero three times on remote.
    • cqz123
      • Apr 2013
      Vol - and 0 three times does not seem to work. To get into the service menu its Vol- and Info twice and that does work. If that helps narrow down the right key combo. Seems like theres a few different ones out there.
        May be different for your US model & newer generation. What do you see on service menu -- can you show us pictures?
        • Mt.Man
          • Jun 2012
          • 53
          Reset: Hold the TV's Vol Down button and press the Menu button on remote. Should go into a self check and display any SOS error codes in red. Remove AC power or press and hold the TV's power button in for 5 secs, TV will power off and back on. Should now be at open box condition.
          But from your picture, you most likely have a bad A board (main board).
          • cqz123
            • Apr 2013
            Vol Down and Menu didnt do the trick either I'm leaning toward the A board as well. Here's a the service menu like asked above just in case.
              What's under OPTION?
              • cqz123
                • Apr 2013
                Option Menu has
                Option VIVID
                Boot ROM
                WB ADJ Menu
                R-Cut 80
                Before 80
                Format SD
                Method 02
                Color Temp Normal
                ----Adjust Menu
                Adjust Vivid
                Contrast 3C
                YMAX FF
                  LCD LED TV Service Menu Codes
                  TCL LED TV Service Menu Code
                  LG LED TV Service Menu Code
                  10-31-2024, 03:58 AM
                • Andre Gilbert
                  by Andre Gilbert
                  Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                  Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                  11-20-2024, 08:52 PM
                • Robby-Gr
                  TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
                  by Robby-Gr
                  I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality β€” very close to the original.
                  However, since the swap, the TV enters a boot loop (Samsung logo β†’ restart) unless I enter the service menu and perform a reset.
                  The service mode had been previously modified β€” possibly by a technician or during the panel swap β€” and I suspect some key settings are mismatched for the European (Greece) market.
                  Additional issues:...
                  09-27-2025, 12:02 AM
                • Retro140
                  Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
                  by Retro140
                  So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
                  To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
                  06-18-2023, 06:13 PM
                • Lintesir
                  Panasonic P42S30 Plasma - Pink sparkles
                  by Lintesir
                  My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
                  There is about a 5cm high region at the top without any sparkles,...
                  07-26-2024, 03:16 AM
