Samsung PS-42D5SD Blank Screen
    Re: Samsung PS-42D5SD Blank Screen
    The X-main is the only board that uses Ve. A missing Ve would cause a poor picture, but you should still be able to see the image.
    • anotherdude
      • Feb 2013
      • 488
      any more ideas then tom?
      the missing ve voltage is all i've got to go on at the moment
        Have you checked in a dark room for a black-level glow?
        • anotherdude
          • Feb 2013
          • 488
          not sure what you mean, i can see the screen change colour if thats what you mean from off to on, you can see the screen turn on
            So probably main board but possible control board or fuse on address buffers.
            May be that old 480p panel does not use Ve.
            • anotherdude
              • Feb 2013
              • 488
              #26
              time to give up then?
              i can't see why they'd stick the stock voltages on a sticker with all the others including the VE though
              havent since replacing the control board managedf to get it to stay on like i did a few days ago, can't find a main board cheap or in stock so looks like another to get rid of
                I can't sell these plasmas (480p or so) for more than about £60 anyway, so I do not bother fixing them.
                • Chrissygizmo
                  by Chrissygizmo
                  02-10-2025, 12:33 AM
                • mrtek
                  Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                  by mrtek
                  Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                  11-26-2024, 09:58 AM
                • Chrissygizmo
                  samsung galaxy ao2s very temperamental after screen replaced
                  by Chrissygizmo
                  Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                  Ive eventually managed to get it on and working but it's very temperamental...
                  The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                  05-26-2024, 12:05 AM
                • triplefour
                  TCL 65S403 Blank Backlit Screen w/ sound ... voltage besides 12v missing at LVDS
                  by triplefour
                  Blank Backlit Screen w/ sound verified via DVD on HDMi 3
                  no change to display when disconnect tcon
                  no change to display when disconnect panel cables (both sides, one at a time, etc-)
                  can faintly see a vertical dividing line splitting the panel even in half. super faint tho.
                  also can faintly see a black cloud in the center of the screen. a darker area.
                  color of screen is backlit black screen which basically looks gray
                  12v present at TCON fuse
                  other voltages on LVDS cable (TCON side) are missing. only see 2 pins with voltage .69v and .60v
                  10-28-2021, 01:00 AM
                • JunkmanJimbo
                  Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                  by JunkmanJimbo
                  Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                  No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                  Please help. Thanks in advance!
                  08-12-2025, 11:45 AM
